I am using DIVX convertor 6.6.1 to convert the MPEG2 files to divx. letteing the standard "home theator" setting. The mpeg2 input files are always PAL resolution.
But when i load them in the convertor i says that the video's have another resolution?? And when i want to make the output resolution to PAL resolution it doesn't work. I can type the resoltuion in but when i go to the next field it changes back to mostly 720 * 528.
So i choose the: use custom resolution and want to change it to PAL but this isn't working why is that, why can't i change the resolution and why is he choosing the wrong input resoltuion?
	What do you want to encode it as? 720x576, maybe? You do realize that'll give you an incorrect aspect ratio don't you? Are you planning on having your player straighten it out?
	Hi,
 I want to make it 720 * 576 (PAL resolution). Maybe i am mistaken but all the dvd's i make are 720 * 576.
 But now i am converting the dvd's to divx avi so i can put 4-5 movies on 1 dvd and play them in the car on the dvdplayer wich supports divx avi. I have tested this with 2 divx avi and when i put the disc with the avi in the car it shows the avi's and then i can select them and play them. This is what i want with 5 movies on 1 dvd.
 But why can't i change the aspect ration to 720 * 576? Is this not nessesairy?
  Reconverting Divx videos to smaller Divx files.. strange resolutionBy arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35
  resolution divxBy surfer in forum DVD RippingReplies: 22Last Post: 6th Jul 2008, 09:28
  Xilisoft DVD to Divx ConvertorBy didikai in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2008, 15:23
  hd -> divx using divx convertorBy uk_dan2k in forum Video ConversionReplies: 3Last Post: 2nd Jan 2008, 16:57
  Cropping in Divx Convertor or Divx Author???By rahul.never2far in forum EditingReplies: 9Last Post: 25th Sep 2007, 11:28
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
