I have downloaded a movie with extension ".AVI" but windows doesnt seem to recognise it! I can play it with my windows media player (latest) but when I try to open it in TMPGEnc it says it is "unsupported" HELP!!! What can I try? What can I use to convert it??
you do not have the right codecs, other users have had this prob also. Got http://www.divx-digest.com and download the alpha 3.11 and everything will work just fine for you.
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 1st Aug 2007, 23:41 -
Converting DV AVI to xVid AVI (with AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 6Last Post: 5th Jul 2007, 00:56 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 09:57
