I want to burn the Video_TS and Audio_TS folders off my C drive to a DVD disc using ImgBurn, but ImBurn will only burn a file and not these folders. How do you make ImBurn just burn two folders?
Switch ImgBurn to 'Build' mode (Mode menu > Build, or Ctrl-Alt-B), and drag the VIDEO_TS and AUDIO_TS folders to the large window on the left side of the main window. Then, all you have to do is hit the Write button.
If cameras add ten pounds, why would people want to eat them? -
On the Build mode, once I put in the folders it does not give a Write button in that mode. I don't want it to create a ISO on the hard drive to then burn it there to the DVD disc. So I have the two folders loaded in the Build mode page, now how do I burn directly from here to the DVD disc. Again, I don't see a Write button located onthe Build mode page.
From the Output menu, pick "Device".
Sorry about that; I just assumed you already had Output to Device selected.
Error when burning to DVD with ImgBurn
By drkzero in forum DVD RippingReplies: 13Last Post: 4th Feb 2012, 19:07 -
Blocks after burning Imgburn
By Russo in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2011, 19:31 -
Burning with Imgburn
By Ronny G in forum Authoring (DVD)Replies: 7Last Post: 16th Mar 2008, 18:37 -
burning error using imgburn DVD9
By mvp in forum Newbie / General discussionsReplies: 6Last Post: 4th Nov 2007, 00:04 -
Can DVDShrink be set to use ImgBurn for burning?
By RoyGBiv-inRI in forum DVD RippingReplies: 7Last Post: 21st Jul 2007, 13:17
