Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Jan 2004
    Queens
    I was surfing and found Digital Media Converter @ http://www.deskshare.com/dmc.aspx
    Well is says it converts all these formats, But, I'm especially interested in converting Pal to NTSC only since I read on their website it cannot do menus. I know there is alot of articles on how to do the conversion in videohelp, but perhaps this software can do it a bit easier. Just wondering if anyone has tried it. It has a trial version, but very limited. If it's good, I would spend the cash on it, but again trying to see if anyone else has tried it. Thanks
    Aug 2004
    you should take out the comma at the end of the link
    if that's the only thing you want to get out of this software, then it's not worth the money
  3. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    I find one of the easiest programs to do that type of conversion is ConvertXToDVD. At least I seem to get fairly uniform results with it and the cost is low enough.
    Or for simple conversions, even SUPER.
    EDIT: BTW, I fixed your link to DMC.
    Jan 2004
    Queens
    But ConvertXtoDVD you need to converto to AVI first, then to DVD afterwards. Too many steps.
    Dec 2004
    Triptonia
    you're wrong.
    you can drag the relevant vts ifo into convertx, if you're talking about dvd to dvd.
    Jan 2004
    Queens
    Wow never new that. Thanks, that will help since convertxtodvd is the best program i ever used. Thanks again.
