I keep getting an error when I try to burn my movies. I convert with Concertxtodvd first then build iso in imgburn and then try to burn or write the file. I worked a couple times and now won't work at all. Here is the log from the last try...
I 16:11:23 Operation Started!
I 16:11:23 Source File: C:\Documents and Settings\HP_Owner\My Documents\ConvertXtoDVD\madagascar.iso
I 16:11:23 Source File Sectors: 2,132,912 (MODE1/2048)
I 16:11:23 Source File Size: 4,368,203,776 bytes
I 16:11:23 Source File Volume Identifier: madagascar 25
I 16:11:23 Source File Application Identifier: IMGBURN V2.3.2.0 - THE ULTIMATE IMAGE BURNER!
I 16:11:23 Source File Implementation Identifier: ImgBurn
I 16:11:23 Source File File System(s): ISO9660, UDF (1.02)
I 16:11:23 Destination Device: [0:0:0] LITE-ON DVDRW SOHW-1633S BPSA (E(ATA)
I 16:11:23 Destination Media Type: DVD-R (Disc ID: MCC 02RG20) (Speeds: 4x, 6x, 8x)
I 16:11:23 Destination Media Sectors: 2,298,496
I 16:11:23 Write Mode: DVD
I 16:11:23 Write Type: DAO
I 16:11:23 Write Speed: MAX
I 16:11:23 Link Size: Auto
I 16:11:23 Test Mode: No
I 16:11:23 BURN-Proof: Enabled
I 16:11:24 Filling Buffer... (20 MB)
I 16:11:25 Writing LeadIn...
I 16:12:14 Writing Image... (LBA: 0 - 2132911)
W 16:13:01 Waiting for buffers to recover...
W 16:13:02 Waiting for hard disk activity to reach threshold level...
I 16:13:03 Writing Image...
W 16:15:25 Failed to Write Sectors 53952 - 53983 - Cannot Write Medium - Incompatible Format
W 16:15:25 Retrying (1 of 20)...
W 16:15:25 Retry Failed - Cannot Write Medium - Incompatible Format
W 16:15:25 Retrying (2 of 20)...
W 16:15:25 Retrying (3 of 20)...
W 16:15:25 Retrying (4 of 20)...
W 16:15:25 Retrying (5 of 20)...
W 16:15:25 Retrying (6 of 20)...
W 16:15:25 Retrying (7 of 20)...
W 16:15:25 Retrying (8 of 20)...
W 16:15:25 Retrying (9 of 20)...
W 16:15:25 Retrying (10 of 20)...
W 16:15:25 Retrying (11 of 20)...
W 16:15:25 Retrying (12 of 20)...
W 16:15:25 Retrying (13 of 20)...
W 16:15:25 Retrying (14 of 20)...
W 16:15:25 Retrying (15 of 20)...
W 16:15:25 Retrying (16 of 20)...
W 16:15:25 Retrying (17 of 20)...
W 16:15:25 Retrying (18 of 20)...
W 16:15:25 Retrying (19 of 20)...
W 16:15:26 Retry Failed - Cannot Write Medium - Incompatible Format
W 16:15:26 Retrying (20 of 20)...
E 16:15:31 Failed to Write Sectors 53952 - 53983 - Cannot Write Medium - Incompatible Format
I 16:15:32 Synchronising Cache...
E 16:15:33 Failed to Write Image!
E 16:15:33 Operation Failed! - Duration: 00:04:09
I 16:15:33 Average Write Rate: 550 KB/s (0.4x) - Maximum Write Rate: 2,432 KB/s (1.8x)
Please help me and figure out what I am doing wrong....I am clueless
i just burn the the video_ts folder using the build mode, I don't even create an ISO
if its the same media as before , from the same spindle, i would suspect a burner problem
what is the listed speed of the media, and what speed are you burning at
i always burn at 1/2 the max speed listed, 8x media I burn at 4x takes 12 to 20 minutes for 1 dvd
no coasters that way, in my experience you can't burn at max speed unless you use top quality discs and a pro/semi-pro burner, NOT the one that came in the PC -
Update, please help...
I changed the media, I changed the write speed and i tried to burn the video_ts folder using build mode. Still get the same error! HELP I am an idiot at this
[ASK] Error Burn BD with Imgburn
By m1x in forum Blu-ray RippingReplies: 5Last Post: 30th Jun 2010, 11:25 -
ImgBurn Error Message
By kwebster in forum DVD RippingReplies: 5Last Post: 24th Nov 2008, 14:11 -
ImgBurn error
By tim_ver in forum Authoring (DVD)Replies: 10Last Post: 27th Dec 2007, 17:09 -
ImgBurn I/O Error
By trunkims in forum Authoring (DVD)Replies: 12Last Post: 12th Sep 2007, 17:43 -
ImgBurn Error?? I keep getting this...
By sandman423 in forum Authoring (DVD)Replies: 2Last Post: 2nd Jun 2007, 00:08
(ATA)
