I am having issues since last night of not being able to burn a DVD Data Disc containing Divx files... I keep getting the error "Could not perform end of Disc-at-once"... I suspect that it may be that my writer, that is only 2 weeks old, is not liking the discs that I am using... Verbatim AZO 16X. They were only $12.99 for a 50 pack and I guess I should have known better... You get what you pay for...
Anyway, I am pasting the log from the last disc that I tried to burn and would appreciate and advice or insight on this matter.
Thank you, Patrick
5C80001080100000000465223158
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 11/21/2005 12:48:21 AM
NT-SPTI used
Nero Version: 7.0.1.2
Internal Version: 7, 0, 1, 2
Recorder: <PIONEER DVD-RW DVR-112> Version: 1.16 - HA 1 TA 6 - 7.0.1.2
Adapter driver: <USB> HA 1
Drive buffer : 2000kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <COMBI RW16x10/DVD >Version: H1.0 - HA 1 TA 0 - 7.0.1.2
Adapter driver: <IDE> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD600AB-22CBA1 atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST380021A atapi Port 0 ID 1 DMA: On
CdRomPeripheral : COMBI RW16x10/DVD atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HP CD-Writer+ 9500 atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
COMBI RW16x10/DVD F: CDRom0
HP CD-Writer+ 9500 G: CDRom1
PIONEER DVD-RW DVR-112 H: CDRom8
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 254MB (260632kB)
Free physical memory: 103MB (106116kB)
Memory in use : 59 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
9.6.2007
ISO compilation
10:42:50 AM #1 Text 0 File Isodoc.cpp, Line 6411
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
10:42:50 AM #2 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 39936KB of Memory
10:42:50 AM #3 Text 0 File Reader.cpp, Line 124
Reader running
10:42:50 AM #4 Text 0 File Writer.cpp, Line 113
Writer H: PIONEER DVD-RW DVR-112 running
10:42:50 AM #5 ISO9660GEN -11 File Geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
10:42:50 AM #6 Text 0 File Burncd.cpp, Line 3302
Turn on Disc-At-Once, using DVD media
10:42:50 AM #7 Text 0 File DlgWaitCD.cpp, Line 279
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1033327 (229:37.52, 2018MB)
10:42:50 AM #8 Text 0 File DlgWaitCD.cpp, Line 291
Write in overburning mode: NO (enabled: CD)
10:42:50 AM #9 Text 0 File DlgWaitCD.cpp, Line 2578
Recorder: PIONEER DVD-RW DVR-112, Media type: DVD-R
Disc Manufacturer: MCC 03 - RG20
Disc Application Code: 64, Disc Physical Code: 193
10:42:50 AM #10 Text 0 File DlgWaitCD.cpp, Line 458
>>> Protocol of DlgWaitCD activities: <<<
10:42:50 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1033328 (1033328) = #1033328/229:37.53
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1033328 blocks [H: PIONEER DVD-RW DVR-112]
10:42:50 AM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [H: PIONEER DVD-RW DVR-112] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2116255744, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1033328 | lead-out | 1 | 0x41 | 0x00
10:42:50 AM #13 Text 0 File SCSIPassThrough.cpp, Line 36
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
10:42:50 AM #14 Phase 24 File dlgbrnst.cpp, Line 1725
Caching of files started
10:42:50 AM #15 Text 0 File Burncd.cpp, Line 4132
Cache writing successful.
10:42:50 AM #16 Phase 25 File dlgbrnst.cpp, Line 1725
Caching of files completed
10:42:50 AM #17 Phase 36 File dlgbrnst.cpp, Line 1725
Burn process started at 8x (11,080 KB/s)
10:42:50 AM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:42:50 AM #19 Text 0 File DVDR.cpp, Line 2580
Recording mode: Sequential Recording Mode
10:42:51 AM #20 Text 0 File MMC.cpp, Line 21611
Set BUFE: Buffer underrun protection -> ON
10:42:51 AM #21 Text 0 File DVDR.cpp, Line 2735
Start write address at LBA 0
DVD high compatibility mode: Yes
10:42:51 AM #22 Text 0 File Cdrdrv.cpp, Line 8411
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
10:42:52 AM #23 Text 0 File Cdrdrv.cpp, Line 1197
10:42:52.812 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:24 AM #24 Text 0 File Cdrdrv.cpp, Line 1197
10:43:24.437 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:24 AM #25 Text 0 File Cdrdrv.cpp, Line 1197
10:43:24.546 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:24 AM #26 Text 0 File Cdrdrv.cpp, Line 1197
10:43:24.562 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:24 AM #27 Text 0 File Cdrdrv.cpp, Line 1197
10:43:24.578 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:24 AM #28 Text 0 File Cdrdrv.cpp, Line 1197
10:43:24.656 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:24 AM #29 Text 0 File Cdrdrv.cpp, Line 1197
10:43:24.687 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:24 AM #30 Text 0 File Cdrdrv.cpp, Line 1197
10:43:24.703 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:24 AM #31 Text 0 File Cdrdrv.cpp, Line 1197
10:43:24.734 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:24 AM #32 Text 0 File Cdrdrv.cpp, Line 1197
10:43:24.828 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:24 AM #33 Text 0 File Cdrdrv.cpp, Line 1197
10:43:24.843 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:24 AM #34 Text 0 File Cdrdrv.cpp, Line 1197
10:43:24.859 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:24 AM #35 Text 0 File Cdrdrv.cpp, Line 1197
10:43:24.875 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:24 AM #36 Text 0 File Cdrdrv.cpp, Line 1197
10:43:24.890 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:24 AM #37 Text 0 File Cdrdrv.cpp, Line 1197
10:43:24.984 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #38 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.015 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #39 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.031 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #40 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.046 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #41 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.140 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #42 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.156 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #43 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.171 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #44 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.187 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #45 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.203 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #46 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.312 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #47 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.328 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #48 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.343 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #49 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.359 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #50 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.437 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #51 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.453 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #52 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.468 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #53 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.484 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #54 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.500 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #55 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.515 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #56 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.593 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #57 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.625 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #58 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.640 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #59 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.656 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #60 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.671 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #61 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.765 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #62 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.781 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #63 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.796 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #64 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.812 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #65 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.828 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #66 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.921 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #67 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.937 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #68 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.953 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #69 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.968 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:25 AM #70 Text 0 File Cdrdrv.cpp, Line 1197
10:43:25.984 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #71 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.062 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #72 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.078 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #73 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.093 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #74 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.109 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #75 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.125 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #76 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.140 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #77 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.234 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #78 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.250 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #79 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.265 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #80 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.281 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #81 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.296 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #82 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.406 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #83 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.421 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #84 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.437 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #85 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.453 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #86 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.546 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #87 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.562 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #88 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.578 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #89 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.593 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #90 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.609 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #91 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.703 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #92 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.718 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #93 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.734 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #94 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.750 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #95 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.843 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #96 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.875 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #97 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.890 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #98 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.906 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:26 AM #99 Text 0 File Cdrdrv.cpp, Line 1197
10:43:26.921 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #100 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.015 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #101 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.031 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #102 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.046 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #103 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.062 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #104 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.078 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #105 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.171 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #106 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.187 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #107 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.234 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #108 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.734 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #109 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.750 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #110 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.765 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #111 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.781 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #112 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.875 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #113 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.890 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #114 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.906 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #115 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.921 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:27 AM #116 Text 0 File Cdrdrv.cpp, Line 1197
10:43:27.937 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:28 AM #117 Text 0 File Cdrdrv.cpp, Line 1197
10:43:28.046 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:28 AM #118 Text 0 File Cdrdrv.cpp, Line 1197
10:43:28.062 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:28 AM #119 Text 0 File Cdrdrv.cpp, Line 1197
10:43:28.078 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:28 AM #120 Text 0 File Cdrdrv.cpp, Line 1197
10:43:28.093 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:28 AM #121 Text 0 File Cdrdrv.cpp, Line 1197
10:43:28.203 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:43:28 AM #122 Text 0 File Cdrdrv.cpp, Line 1197
10:43:28.218 - H: PIONEER DVD-RW DVR-112 : Queue again later
10:44:53 AM #123 SPTI -600 File SCSIPassThrough.cpp, Line 323
H: CdRom6: SCSIStatus(x00) WinError(121) NeroError(-600)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 00 00 06 E5 A0 00 00 20 00 00 00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x05740000: Len x10000
0xB7 43 EE 5F 0C 83 24 40 8A E7 1E F4 BF CF 1C 0C
0xD0 AC 71 EA 02 93 D3 EF 43 B3 DE C0 3E F5 B8 7D
0x8D CD 67 11 6F 0C C3 34 46 77 BD E8 7B 9E E5 A2
10:44:53 AM #124 CDR -600 File Writer.cpp, Line 302
Device not available
10:44:53 AM #125 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
10:44:53 AM #126 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
10:44:53 AM #127 Text 0 File DVDR.cpp, Line 2978
EndDAO: Last written address was 451999
10:45:13 AM #128 SPTI -600 File SCSIPassThrough.cpp, Line 323
H: CdRom6: SCSIStatus(x00) WinError(55) NeroError(-600)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x5A 00 05 00 00 00 00 00 48 00
Buffer x038b6800: Len x48
10:45:14 AM #129 SPTI -600 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x00
Sense Qual: 0x00
10:45:14 AM #130 CDR -600 File WriterStatus.cpp, Line 167
10:45:14 AM #131 TRANSFER -24 File WriterStatus.cpp, Line 167
10:45:14 AM #132 Phase 38 File dlgbrnst.cpp, Line 1725
Burn process failed at 8x (11,080 KB/s)
10:45:14 AM #133 SPTI -500 File SCSIPassThrough.cpp, Line 323
CdRom6: SCSIStatus(x00) WinError(5) NeroError(-500)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x1E 00 00 00 00 00 00 00 00 00 00 00
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 4/22/2007 7:15:25 PM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 11/21/2005 12:48:21 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.43J, size=36624 bytes, created 4/22/2007 7:15:25 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\usb8023.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=12672 bytes, created 8/4/2004 1:04:32 AM (Adapter driver for rec)
File 'Drivers\usb8023x.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=12672 bytes, created 8/4/2004 1:04:33 AM (Adapter driver for rec)
File 'Drivers\USBAUDIO.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=59264 bytes, created 8/4/2004 1:07:56 AM (Adapter driver for rec)
File 'Drivers\usbcamd.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=23808 bytes, created 8/18/2001 2:00:00 PM (Adapter driver for rec)
File 'Drivers\usbcamd2.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=23936 bytes, created 8/18/2001 2:00:00 PM (Adapter driver for rec)
File 'Drivers\usbccgp.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=31616 bytes, created 8/4/2004 1:08:46 AM (Adapter driver for rec)
File 'Drivers\usbd.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=4736 bytes, created 8/18/2001 7:00:00 AM (Adapter driver for rec)
File 'Drivers\usbehci.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=26624 bytes, created 8/4/2004 1:08:37 AM (Adapter driver for rec)
File 'Drivers\usbhub.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=57600 bytes, created 8/4/2004 1:08:42 AM (Adapter driver for rec)
File 'Drivers\usbintel.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=16000 bytes, created 8/4/2004 1:08:57 AM (Adapter driver for rec)
File 'Drivers\usbohci.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=17024 bytes, created 8/4/2004 1:08:36 AM (Adapter driver for rec)
File 'Drivers\usbport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=142976 bytes, created 8/4/2004 1:08:42 AM (Adapter driver for rec)
File 'Drivers\usbprint.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=25856 bytes, created 8/4/2004 1:01:24 AM (Adapter driver for rec)
File 'Drivers\usbstor.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=26496 bytes, created 8/4/2004 1:08:46 AM (Adapter driver for rec)
File 'Drivers\usbuhci.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=20480 bytes, created 8/4/2004 1:08:37 AM (Adapter driver for rec)
File 'Drivers\usbvideo.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=78464 bytes, created 8/4/2004 1:10:10 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Do yourself a favor and download Prassi Ones and do a "data mastering" (burn a data disc) with it instead. It is small, has no junkware and is a fully functional 30 day trial.
This will also test your theory of a bad drive. -
Thanks! I tried "Ones" and I have been able to burn a few discs with it, but my Pioneer DVD Writer failed to even recognize 3 of the Verbatim Advance AZO 18x discs so far... My question is... Would you, if in my shoes, return the Pioneer Drive before the 30 days is up and exchange for a different writer (In 3 years, my HP external writer performed like a trooper until it finally gave out) or is it possible, that the media sucks?
Thanks again! -
The Pioneer burned the discs correctly with Prassi Ones but then could not recognize the finished product?
OR
The Pioneer couldn't recognize the blank Verbatim before burning....even with/in Prassi Ones? -
The Pioneer couldn't recognize the blank Verbatim before burning....even with/in Prassi One... I am going to buy a different brand of media in the morning and try it... when I first bought the pioneer writer, it had no problem at all with Maxell media.
Thanks! -
from looking at your burn log is your PIONEER 112D housed in a external case? if you're using a external case for it that could be your problem. usually when using a external case you won't be able to burn at high speeds, at the most you'll be able to burn at 12x speed. the VERBATIM dvd media you're using is fine. try burning at 8x or 12x speed. also not all external cases will work with dvd burners depending on the chipset of the case. external cases with the PROLIFIC chipset will work well with most dvd burners. from what i've read the PIONEER drives are fussy when using a external case.
before you decide if your drive is defective try hooking it up internally in your computer and make sure you're using a 80 wire ide cable with the drive otherwise it will not work correctly.
Remove any other usb devices from pc .
Disable "autorun" feature for burner .
Disable "power options" to never for all .
Disable screensaver .
Try burn again .
16x at 8x max , or even 4x if allowed .
Check usb cable is rated for usb2 . -
It appears to have been the friggin' cable!!!
I downloaded a copy of "Ones" and this time when I tried to burn a disc, I received a "communication error" duh... CABLE!!!
Thanks to all for your tips!!!
Matshita BD UJ240AS doesn't work (not perform start of Disc-at-once)
By whenloverageswild in forum Authoring (Blu-ray)Replies: 5Last Post: 11th Nov 2011, 03:08 -
Burning DVD Could not perform end of disk-at-once
By jasonkral in forum Authoring (DVD)Replies: 8Last Post: 14th Feb 2011, 00:05 -
By smt16 in forum DVD RippingReplies: 1Last Post: 18th Jun 2010, 06:50 -
Could not perform end of disc-at-once on dual layer dvd only
By Subhash in forum DVD & Blu-ray WritersReplies: 20Last Post: 25th May 2009, 14:09 -
By mrjoetoff in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2008, 14:27
