I have some video I recorded on my camcorder that is 16x9. I have no problem burning it to a DVD at 16:9, which is fine for my own playback, but I'd like to be able to make copies for a few people without 16x9 televisions.
What is the best way to take my 16x9 video and convert it to, ideally 4:3 letterbox, but if not, then I guess I can live with cropping the sides.
thanks
I don't think you have to do anything.
On the commercial dvds I get I always buy widescreen even though I have a plain old 4:3 tv. I just get it letterboxed automatically. Not sure what my settings are on my players but I think I leave it on fixed or whatever.
Ask them what movies like Star Wars or Titanic look like on their tvs (when they play a widescreen movie). If they say they see the black bars then they have it set to be in letterbox mode already.
It's more a function of the dvd player than what you hardcoded the video to. THough of course you can't easily go from fixed 4:3 to 16x9 but your player does the work to go from 16x9 to fixed.
Maybe some other members here can be a little more specific about my generalities here.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Most DVD players *should* change the video aspect ratio. i.e., if the DVD is flagged as 16:9 and the player is configured for use with a 4:3 standard TV, you should get letterboxing (my cheapo $20 player does).
Alternatively, if the original videos are DV, you can do real-time (or fast) conversion with our Enosoft DV Processor. You can do this at capture time or, if you want to keep the native 16:9 file, you can create converted files from the originals.John Miller -
Thanks for the replies. I understand that an anamorphic dvd will letterbox on 4:3 TV. But I was concerned that the video recorded by my camcorder was different. In other words, I had assumed that anamorphic dvds contained certain information that allowed the letterboxing. I'll try the 16:9 dvd I made from my camcorder on a 4:3 tv and see how it looks.
Thanks for the help. -
There's no difference between a commercial 16:9 and your 16:9. As long as the flag is set properly it will work providing the player is set up right. If not neither will work correctly.
Is it possible to re-edit a non-anamorphic dvd to anamorphic?
By Beautiful Alone in forum DVD RippingReplies: 45Last Post: 22nd Sep 2011, 09:00 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 15:46 -
Letterbox 4:3 to Anamorphic 16:9
By sjdean in forum Video ConversionReplies: 4Last Post: 29th Nov 2009, 16:09 -
Test for Anamorphic?
By Nelson37 in forum Newbie / General discussionsReplies: 25Last Post: 28th Sep 2007, 19:16 -
anamorphic or not anamorphic
By cd090580 in forum Video ConversionReplies: 3Last Post: 23rd Jun 2007, 12:48
