Hi everyone!
Im trying dvdstyler out but i cant seem to figure out how to add subs (srt or another text format sub)
I love it when a plan comes together!
sorry pal
had a little look in the user manual of it for you (pdf on the homepage)
pg 45 - "At present, DVDStyler v1.31 does not support subtitles"
Your best bet would be to author it normally using the program and then use some other utility to mux them in seperately later. May need to save the DVDStyler project, close the program, then play with the XML file directly before re-opening it to create the disc structure (but NOT burn), in order for it to actually have the capability of playing the subtitles later muxed into the file.
(or this might in turn kill the authoring process. hmm.)
don't take my word for it though, i only started using the thing myself a few days ago
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more! -
the changelog here and at the homepage says-:
it doesnt say it was removed after that version, i was thinking the subtitle options were deep buried in the program but i aslready tried all the menus and there was no sign of it.1 December 2005: DVDStyler v1.5 beta 3 Released!
Changes:
* added support of subtitles and several audio tracks
i'll have to try the other Gui´s for dvdautor.
Thanks EddyHI love it when a plan comes together! -
Hmmm, there ARE options for selecting subtitle stream, etc, in the properties of each video item you add - but I think it's only for setting what subtitle displays by default (and which audio plays, etc, etc) out of several pre-existing tracks within an already-muxed VOB.
How do I add .srt subs to avi?
By 12 gage in forum SubtitleReplies: 16Last Post: 1st Jun 2014, 17:58 -
add subs failed.
By izzykatz in forum SubtitleReplies: 2Last Post: 2nd Jan 2011, 17:52 -
Add Subs
By AntiBaltak in forum SubtitleReplies: 11Last Post: 9th Nov 2009, 19:00 -
How do i add subs to my videos?
By mrjust in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2009, 19:29 -
DVDStyler - How to add subtitles?
By user2008 in forum Authoring (DVD)Replies: 1Last Post: 22nd Dec 2008, 09:23
