i converted an avi file to dvd and burnt it with VSOConvertX and when i play it on my dvd the frame rate is choppy. u cant really notice it until the picture is moving sideways....
what is the problem here?
it doesnt do this everytime i convert avi to dvd and burn it, only maybe 1 out of 10 discs...
Results 1 to 14 of 14
what would be a good alternative?
freeware would be best... unless i can download a crack....
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator BJ_M
i cant play those.. so no use in converting to that
what is another good avi to dvd convertor?
could it be that i was burning the file too fast and it cuased a choppy playback?
and im sorry i mentiond "warez" there.. sorry about that mods.. cant i have this yellow box taken out of my profile? lol -
If you convert 23.976 fps source to 23.976 fps DVD using pulldown (ConvertXtoDVD does this) then you will not get stuttering. If you convert 25 fps or 23.976 fps to 29 fps then you will get stuttering because you are creating duplicate frames to fill out the framerate. If you are converting source with any other framerate then you are either dealing with crap (WMV and RMVB can both have variable framerates which do not convert well), or perhaps, if you are lucky, HD source.
If you have 25 fps source that needs to be converted then you need to search for the guides for PAL to NTSC using Pulldown, and do the encoding and conversion manually.
ConvertXtoDVD is the only one-click tool that correctly applies pulldown, so NTSC source conversions should not stutter.
You could look at DVD Flick as an alternative. I would not consider any of the payware tools - WinAVI, NeroVision etc - as they are all far inferior to ConvertXtoDVD in so many ways.
Of course, without you explaining anything at all about your source, and having only your vague description of the problem, I cannot say for certain that anything in particular will fix your problem.Read my blog here.
you say choppy, and then you say it shows on sideways HORZ movement
do you mean the jaggies ? along the edge of the moving object/person, that is a de-interlacing issue, something differernt from choppy/stuttering video -
The latest versions of ConvertXtoDVD have some built in filters, including a deinterlace filter. This is turned on by default (which makes no sense to me at all). Turn this off and try again.
Read my blog here.
well when the camera is moving sideways, it flickers, but when the camera is not really moving, its fine. only when its a side ways movement, the fps flickers/gets choppy
Is this what you are seeing ?
http://neuron2.net/LVG/interlacing.htmlRead my blog here.
That sounds like an interlaced video burned with the wrong field order. Is the shake very fast? Like 30 times a second?Originally Posted by NateDizzle
Thats what i was going to suggest. I had an old capture card that used bottom field first. When I encoded i used top field first and got that same stutter. I used restream and checked the box top field first to fix the problem.Originally Posted by jagaboDonadagohvi (Cherokee for "Until we meet again")
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 06:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 23:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 05:53 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17
