I have an ATI TV wonder card that I record TV shows (mainly WWE wrestling).Ok,in the spec,it captures in 29.97 fps(I'll round it to 30 fps).I have some games that I record (and again WWE))that run 60 fps (again I'm rounding).When I capture and play it back,it still runs smooth @ 60 fps.Am I misunderstanding the specs for my card.I realize that the NTSC standard is 29.97,but some TV shows and games run at 60 fps.Someone please correct me if I figured this wrong.If I am wrong,then what makes the difference in smoother looking TV programs and games compared to others?If I am right,how can my capture card record at a higher framerate than is in the specs?Reason I ask is I've seen some encoded wrestling programs and they are not near as smooth as the original tv broadcast,yet when I record with my card and convert to DVD,I get that same smooth framerate as the TV.I'd just like to get framerate questions straighted out.Thanks for any helpful info.
Normal NTSC TV is 29.97 frames per second but interlaced with odd and even fields. Fields update at 59.94 rate and provide 60Hz equivalent motion resolution.
If you were to deinterlace through a blend or weave, the two fields are merged into one causing motion update to drop to 29.97 Hz.
A bob deinterlace expands each field into a frame through interpolation. The result is then 59.94 frames per second with 60 hz motion. The downside of a bob is flicker in still areas. For this reason a bob is usually combined with motion detection to turn it on or off.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Best framerate conversion? (eg: 23.97 to 30 fps to avoid judder)
By ionone in forum Video ConversionReplies: 16Last Post: 12th Mar 2014, 08:56 -
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 06:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 23:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 05:53 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17
