All -
I apologize in advance for being such a "newbie" and asking this simple question. I've done some research on this board and would like to make sure what the proper solution is to my problem.
The channels (both HD and non-HD) are slightly fuzzy where it seems to blur or have a slight catch up time during on-screen movements. I've tested the TV with my XBOX 360 and my DVD player and am not having the same issue. From what I've seen on the board, I need to either get an HD cable or a smart card for my cable box. Is it safe to assume that once I get these two things the problem will go away? Or is there perhaps another solution? Thanks!
				Results 1 to 16 of 16
	do you have it hooked up with component cables ?? "Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
	Yes, it is hooked up with component cables from the TV to the Comcast cable box
	Is the comcast box a HD box ?
 have you set it up for 1080i and 720p output ?
 some cable (a lot) is very high compression even on hd channels -- never going to ook perfect ...
 also what is your signal level of your cable line ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
	The Comcast box says it's HD capable, however, we do not have the additional HD service from Comcast. Unfortunately, I don't even know how to set it up for the 1080i and 720p output.
	if it is not authorized for hd -- you prob dont have hd .....
 go into the start up menu and see what it will output ... or
 call comcast and just ask them
 without knowing what kind of box it is and what os it is running -- i cant give you more detailed directions"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
	Does the cable box look like this?
 If so and you have HD service set menu
 TV Type = 16:9
 YPbPr Output = 1080i or 720p whichever looks better
 4:3 Override = 480p
 If you can't get HD to work use 480p
 TV Type = 16:9
 YPbPr Output = 480p
 4:3 Override = 480p
	OK here's my update. I just switched out the box and hooked up the HDMI cable. However, still having the same problem. I don't know if my expectation is too high and this is the picture I'm supposed to get, but it seems to be fuzzier than I had anticipated. Any advice on what to do now that I have the HDMI cable and it is plugged into the cable box?
	I have this exact set, olevia 232v. It was $424 at Circuit city about ten days ago and a buddy and I both bought them. We both have several makes of hd lcds and the 232 are as good or better including on SD content. It beats the pants off my buddy's vizio and holds up pretty well against my samsung considering them massive price difference.
	I don't know if that's good news to hear or not. It seems like a great deal but the fact I'm battling with less than perfect clarity is troubling. What settings do you have it on?
	its called, approperatly, "Motion Blur" its due to the fact that the panels that they use in those tv's have a typical response time of around 12ms. the use of a digital connection like HDMI will help, but only slightly. this is common to all lcds to some extent, but some people notice it more than others. just like DLP rainbows.Originally Posted by bjorgens
	Does a progressive 480p DVD look any better or worse?
 Did you try 720p out of the cable box? That forces the cable box to do the deinterlace.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	so because they're 8ms as opposed to 12ms there is a slight motion blur that I'm going to have to live with? There is a difference between TV channels and viewing DVDs/Xbox-360 games - the picture is clearer for the latter.
	Are you sure its LCD lag and not deinterlace blurring? To see LCD lag only test with a progressive DVD (high quality movie) playing in a progressive DVD player in 480p/59.94 over analog component or HDMI. If you still see blur, that is LCD lag.Originally Posted by bjorgens
 Another way is to directly tune OTA (not cable or satellite) an ABC or FOX 720p/59.94 sports broadcast.
 And...
 TV Type = 16:9
 4:3 Override = 480p
 TV Type = 16:9
 YPbPr Output = 480p
 4:3 Override = 480p
 If you happened to read this, much Later.
 To enter the HD service Menu the cable box must be turned "Off", TV must be "On" and in the Input that corresponds to the Cable Box(i.e. YPbPr-Component, HDMI, or DVI) and you must press the menu button on the Front of the Comcast HD Capable Box.
 Then the gray Service Menu screen will appear.
 Once you are done with the above settings, to your preferences, then you press the menu button on the Front of the Comcast HD Capable Box to exit the gray Service Menu.
 I hope this helps!
 Later,
 The Cobe
  "Live" picture effect - pictures end up "filmized"By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 12:59
  Set/Fix QuickTime "atoms"/"flags"?By rumplestiltskin in forum Newbie / General discussionsReplies: 3Last Post: 22nd Sep 2008, 14:07
  Attempting to demux VOB gives pop-up "file error" window eight tiBy taa in forum ffmpegX general discussionReplies: 6Last Post: 31st Aug 2008, 03:02
  Olevia 227V 27 "By zukie23 in forum DVB / IPTVReplies: 1Last Post: 4th Dec 2007, 02:48
  How to fix "twitchy' or "jerky" .asf files.By bbanderic in forum Video ConversionReplies: 2Last Post: 21st Sep 2007, 18:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
