i'm converting frame sequence renders from Maya using ffmpeg on linux. i'd like to make high-quality video files to then take into editing/compositing in, say, Kdenlive, Jahshaka, Cinelerra, or on mac or windows, aftereffects. ideally i'd want to use QTRLE but apparently ffmpeg will only decode it.
is there another lossless, or close-to-lossless, codec i can use? or some good default settings to use to get high-quality results? ideally, one that'll be read by quicktime, too.
with ffmpeg you basically have 4 options.
ffv1, huffyuv, dv and mjpeg.
With the first two you get lossless but,
ffv1 and huffyuv aren't yet supported in cinelerra.
don't ever expect ffv1 to work with quicktime.
i haven't seen a huffyuv plugin for quicktime...
with dv and mjpeg, you get standard editing formats and you can use what you like,
but you move into lossy.
i think your best option is jahshaka which can take huffyuv and
i believe you can come straight in from maya.
anyway,
try a few things out.
gl
FFMPeg Issue : Codec ID#
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Oct 2010, 15:10 -
Directshow filter for the Animation codec
By roflwaffle in forum Video ConversionReplies: 8Last Post: 12th Oct 2010, 15:09 -
ffmpeg codec id 86055
By heruvim in forum Video ConversionReplies: 1Last Post: 11th Dec 2009, 09:15 -
Unsupported codec (id = 0) in ffmpeg
By Nightslk in forum Video ConversionReplies: 3Last Post: 10th Nov 2009, 17:17 -
quicktime animation codec - fps problem
By phpmysql348 in forum Video ConversionReplies: 0Last Post: 28th May 2008, 06:36
