If I want to have DVD's I burn to be compatible on the most DVD players - both in being able to be played & in playing well - which should be used: DVD+ or DVD-? I would be very interested to see which way the majority go. Thanks.
Results 1 to 15 of 15
There is no such thing as a "minus" disc. You don't call it "DVD minus R" anymore than you'd call it a "CD minus R" disc.
It's simply "DVD R" and "DVD plus R".
At any rate, just use good discs. Verbatim DVD-R or Taiyo Yuden DVD+R
Read more at www.nomorecoasters.comWant my help? Ask here! (not via PM!)
If they are modern players, it won't make any difference so long as you use good quality discs. On older players +R is less compatible unless they are +R specific. Bitsetting +R discs can close the gap some way.
I rarely use +Rs and have never had a playback problem that could be traced to disc format.Read my blog here.
if your burner can bitset dvd+r to dvd-rom then dvd+r is as compatible as dvd-r. if not stick to dvd-r.
heh, popular poll ... my vote makes it 50-50
it seems more really that you tailor what you use to the hardware it needs to be played on.... the twin format thing is a pain that way.
personally i use mainly +R as it seems more reliable and more compatible with my own equipment. -R is ok, but seems more failure prone and my DVD player hates it with a passion. +RW vs -RW is more moot; surprisingly the player likes -RW just fine, and it actually seems to be slightly better quality / more resilient than +RW... but it also doesn't have that handy "no reformatting necessary" high-speed overwrite feature
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more! -
If you plan to use a dvd recorder, look carefully at the specifications. I found, for example, the LG RC797T can record to both dvd-r/rw and dvd+r/rw but it is easy to edit out commercials with -rw and not all with +rw.
odd... you mean it doesn't use VR properly with +RW media? (even though ostensibly they're easier to overwrite)?
The full test of the edit features are on this thread,
https://forum.videohelp.com/topic279460.html -
Hmmm. It does look like it falls down a bit in some other areas too, maybe as a side effect of cramming a vhs player into the same box... no SVideo input, other oddness with +RW vs -RW and RAM, recording modes, etc.
Interesting and informative thread there, even if OMG REPETITIVE IMAGE OVERLOAD. I was thinking of getting a DVD recorder. I shall check back there first on the details of it... or perhaps search around the site to find similar reviews of PAL / DVB-T hardware... (now all I need is somewhere that hosts reviews of audio equipment along the same lines - i need a new stereo but don't want to be landed with a clunker, and most magazines seem concerned more with expensive seperates and turntables that "offer outstanding value"... at £2995... o_O... my CAR cost less than that, jeez-= She sez there's ants in the carpet, dirty little monsters! =-
I have more luck with +R's playing in my own standalone player, but if I send any out to other people they're usually -R's (8x if I can spare them).
This has been discussed here many months ago. Although I understand your point because DVD–R is supposed to be written with a dash and not a hyphen, it is still my opinion that to call it minus is logical and convenient. Most people, including you and some DVD media makers, write it with a hyphen. If we will strictly stick to "dash" principle, how will we read this: DVD±RW? It will be confusing to read it with silent "dash" sign, if it were really a dash.Originally Posted by lordsmurf
http://en.wikipedia.org/wiki/DVD-R -
I'm sure that puts a smile on the face of Ricoh/Sony/Philips. Their goon marketing has worked on somebody. But it's still not correct.Originally Posted by edong
No such "DVD±RW" format exists. The correct verbiage for this is "dual-format DVD burner".Originally Posted by edongWant my help? Ask here! (not via PM!)
If somebody asks me what "dual" refers to, I will say one is for +R and the other to R. Just ignore the other sign. And it is more correct to refer the DVD±RW as dual-format DVD burner than DVD-R as DVD minus R (to distinguish it from DVD+R). Perhaps, if they did not invent the +R format . . . .Originally Posted by lordsmurf
I was always told it was "plus R" and "dash R"
Where in the world is "-R" media ever written just as "R"?
hmmm...
anyway who cares so long as it allows you to easily identify between the two major types eh?
Had further funs with it; the laptops at work seem to like everything except +R... incompatibility HO!!! Damn format wars.
(then again the drives do seem generally faulty and have +R/RAM markings on, so how can you ever be sure?)-= She sez there's ants in the carpet, dirty little monsters! =-
DVD-R (Verbatim Advanced Azodye)
The -R and -RW variants support a whole bunch of features not available with +R and +RW. My standalone Sony DVD recorder can do all kinds of nifty things with -R and -RW.
track 3 = track 1 minus track 2 ??
By tigermann74 in forum AudioReplies: 6Last Post: 31st Mar 2011, 04:29 -
What does it mean when subs have a minus before the text?
By DVMaster in forum SubtitleReplies: 2Last Post: 29th Jan 2010, 00:56 -
Are DVD-R/DL (double layer MINUS R) incompatible with ISO/MDS for +R/DL?
By miamicanes in forum DVD RippingReplies: 16Last Post: 31st Dec 2009, 21:24
