I've been burning 'Editable DVD's' to DVD+RW with no problem using NVE, giving me a screen to layout the menu. I've popped a DVD-RW into the drive but NVE skips the screen(s) that relate to the menu. Instead, it goes from where I select files from my harddrive, almost straight to the 'Burn' screen. I then tested it by choosing 'DVD' rather than 'Editable DVD' and the menu options became available. Does anyone know why this would be?
	Do you mean, nic2k4, that you had no menu when using DVD-RW either?[/quote]that's the "feature" I was looking for
	There is a difference between DVD+VR and DVD-VR (Nero's Editable DVD) . With DVD-VR there is no menu, but a playlist can be created. Also note that with -VR the audio cannot be altered/changed as with +VR. Stick with your +RWs for maximum flexibility.
  Play All option STILL goes to menu after each chapterBy stevencarl in forum Authoring (DVD)Replies: 1Last Post: 5th Oct 2011, 14:17
  XVID to DVD with a menu with selectable subtitle optionBy Khaliji in forum Authoring (DVD)Replies: 20Last Post: 6th Feb 2011, 22:29
  Ulead DVD MovieFactory 6 Plus Menu Option QuestionBy SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 14:42
  Flag for Menu OptionBy Seeker47 in forum Authoring (DVD)Replies: 1Last Post: 11th Aug 2008, 14:46
  Menu OptionBy k_vic in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 9th Aug 2007, 08:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
