when i create a dvd with 2.5 i can see vertical lines, these are not there when I use 2.1. I have tried various xvids and the outcome is the same with all of them, lines on 2.5, none on 2.1
I have also tried this on another pc(clean install with xp and then vista x32) and a laptop and the same happens
Results 1 to 29 of 29
Ok. Can you post your log or email me so that i can try the same source?
Here is the log from 2.1
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.1
Version: 2.1.2474.30185
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2\SVCD2DVD.exe
Executable size: 2.86 MB
Executable size in bytes: 3006547
Executable CreationTime: 10/10/2006 16:57:38
Executable LastWriteTime: 08/06/2007 11:25:12
Executable LastAccessTime: 09/06/2007 13:05:24
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 1.99 GB
Free Physical Memory: 1.29 GB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.95 GB
***************************** Computer *****************************
Computer Manufacturer Name: MSI
Computer Model: MS-7250
System Type: X86-based PC
Computer Name: PDS-40466724245
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 2
User Name: PDS-40466724245\pds
***************************** Processor ****************************
Manufacturer: AuthenticAMD
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4600+
Description: x86 Family 15 Model 75 Stepping 2
CPU Speed: 2.399GHz
CPU FSB: 200MHz
L2 Cache Size: 1.00 KB
CPU Speed: 2.399GHz
CPU FSB: 200MHz
14:05:34: Logical CPUs: 2
***************************** Time Zone ****************************
Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Name: NVIDIA GeForce 6800
Processor: GeForce 6800
Mode: 1280 x 1024 x 4294967296 colors
Video Ram: 128 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 81.1 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 78.6 GB
DeviceID: G:
FileSystem: NTFS
FreeSpace: 213 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<SVCD2DVD DateTime="09/06/2007 14:05:34" Filename="NONE"><AssetSet><Asset ID="51db2f63-65be-4940-af33-5e8f946bdf19" Path="C:\avimux" Filename="sling.avi" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="49" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="sling.avi" AssetID="51db2f63-65be-4940-af33-5e8f946bdf19" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2\default.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="" InitialDVDFolder="E:\" InitialProjectFolder="E:\" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Custom_ac3" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="ac3" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="ImgBurn 2+" DVDDrive="PIONEER DVD-RW DVR-109 " NeroWriteSpeed="Max" Eject="False" HighDVDCompat="False" VerifyDVD="False" ImgBurnPath="C:\Program Files\ImgBurn\ImgBurn.exe" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 697 MB
file=C:\avimux\sling.avi
FormatName=avi
Num_Frames=129583
DurationInSecs=5404
Duration=01:30:04.0
VideoCodec=mpeg4
Width=624
Height=352
Standard=NTSC (Film)
BitRate=1082
AudioStreamCount=1
Audio1StreamID=[0x1]
Audio1SampleRate=48000
Audio1Codec=mp3
Audio1BitRate=32
Audio1Channels=2
AVI2MPG: 6264kbs Full-D1
14:05:34: Looking for AVI PAR...
Pass 1/1: Processing sling.avi
14:05:35: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
14:05:35: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
14:05:35: libavutil version: 49.0.0
14:05:35: libavcodec version: 51.4.0
14:05:35: libavformat version: 50.2.1
14:05:35: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
14:05:35: Input #0, avi, from 'C:\avimux\sling.avi':
14:05:35: Duration: 01:30:04.0, start: 0.000000, bitrate: 1082 kb/s
14:05:35: Stream #0.0, 23.98 fps(r): Video: mpeg4, yuv420p, 624x352
14:05:35: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 32 kb/s
14:05:35: Output #0, dvd, to 'C:\avimux\sling_S2D.mpg':
14:05:35: Stream #0.0, 23.98 fps(c): Video: mpeg2video (hq), yuv420p, 720x480, q=1-31, 6264 kb/s
14:05:35: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
14:05:35: Stream mapping:
14:05:35: Stream #0.0 -> #0.0
14:05:35: Stream #0.1 -> #0.1
14:48:10: video:3131730kB audio:295528kB global headers:0kB muxing overhead 1.886308%
14:48:10: AVI2MPG: done.
NTSC(Film)->NTSC: demuxing sling_S2D.mpg
14:48:11: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
14:48:11: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
14:48:11: libavutil version: 49.0.0
14:48:11: libavcodec version: 51.4.0
14:48:11: libavformat version: 50.2.1
14:48:11: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
14:48:11: Input #0, mpeg, from 'C:\avimux\sling_S2DNTSC(Film).mpg':
14:48:11: Duration: 01:30:01.6, start: 0.500000, bitrate: 5295 kb/s
14:48:11: Stream #0.0[0x1e0], 23.98 fps(r): Video: mpeg2video, yuv420p, 720x480, 9000 kb/s
14:48:11: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, stereo, 448 kb/s
14:48:11: Output #0, rawvideo, to 'C:\avimux\sling_S2DNTSC(Film).mpv':
14:48:11: Stream #0.0, 23.98 fps(c): Video: mpeg2video, yuv420p, 720x480, q=2-31, 9000 kb/s
14:48:11: Output #1, ac3, to 'C:\avimux\sling_S2DNTSC(Film).ac3':
14:48:11: Stream #1.0: Audio: ac3, 48000 Hz, stereo, 448 kb/s
14:48:11: Stream mapping:
14:48:11: Stream #0.0 -> #0.0
14:48:11: Stream #0.1 -> #1.0
14:52:51: video:3131930kB audio:295528kB global headers:0kB muxing overhead -8.622360%
14:52:51: NTSC(Film)->NTSC: Applying Pulldown sling_S2DNTSC(Film).mpv
14:52:51: SVCD2DVD: Convert2NTSC: Converting....
15:07:11: NTSC(Film)->NTSC: Muxing sling_S2D.mpg
15:13:34: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
15:13:34: INFO: [???] File C:\avimux\sling_S2DNTSC(Film)_pd.mpv looks like an MPEG Video stream.
15:13:34: INFO: [???] File C:\avimux\sling_S2DNTSC(Film).ac3 looks like an AC3 Audio stream.
15:13:34: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
15:13:34: INFO: [???] Found 1 audio streams and 1 video streams
15:13:34: INFO: [???] Selecting dvdauthor DVD output profile
15:13:34: INFO: [???] Multiplexing video program stream!
15:13:34: INFO: [???] Scanning for header info: Video stream e0 (C:\avimux\sling_S2DNTSC(Film)_pd.mpv)
15:13:34: INFO: [???] VIDEO STREAM: e0
15:13:34: INFO: [???] Frame width : 720
15:13:34: INFO: [???] Frame height : 480
15:13:34: INFO: [???] Aspect ratio : 16:9 display
15:13:34: INFO: [???] Picture rate : 29.970 frames/sec
15:13:34: INFO: [???] Bit rate : 9000000 bits/sec
15:13:34: INFO: [???] Vbv buffer size : 229376 bytes
15:13:34: INFO: [???] CSPF : 0
15:13:34: INFO: [???] Scanning for header info: AC3 Audio stream 00 (C:\avimux\sling_S2DNTSC(Film).ac3)
15:13:34: INFO: [???] AC3 frame size = 1792
15:13:34: INFO: [???] AC3 AUDIO STREAM:
15:13:34: INFO: [???] Bit rate : 57344 bytes/sec (448 kbit/sec)
15:13:34: INFO: [???] Frequency : 48000 Hz
15:13:34: INFO: [???] SYSTEMS/PROGRAM stream:
15:13:34: INFO: [???] rough-guess multiplexed stream data rate : 9653896
15:13:34: INFO: [???] target data-rate specified : 10080000
15:13:34: INFO: [???] Setting specified specified data rate: 10080000
15:13:34: INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
15:13:34: INFO: [???] New sequence commences...
15:13:34: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
15:13:34: INFO: [???] Audio bd: buf= 0 frame=000000 sector=00000000
15:13:34: INFO: [???] STREAM e0 completed @ frame 129565.
15:13:34: INFO: [???] STREAM bd completed @ frame 168872.
15:13:34: INFO: [???] Multiplex completion at SCR=486344557.
15:13:34: INFO: [???] Video e0: buf= 10337 frame=129565 sector=01587541
15:13:34: INFO: [???] Audio bd: buf= 14336 frame=168872 sector=00150110
15:13:34: INFO: [???] VIDEO_STATISTICS: e0
15:13:34: INFO: [???] Video Stream length: 3207096399 bytes
15:13:34: INFO: [???] Sequence headers: 7496
15:13:34: INFO: [???] Sequence ends : 0
15:13:34: INFO: [???] No. Pictures : 129566
15:13:34: INFO: [???] No. Groups : 7496
15:13:34: INFO: [???] No. I Frames : 7496 avg. size 41267 bytes
15:13:34: INFO: [???] No. P Frames : 35694 avg. size 29490 bytes
15:13:34: INFO: [???] No. B Frames : 86377 avg. size 21361 bytes
15:13:34: INFO: [???] Average bit-rate : 4747200 bits/sec
15:13:34: INFO: [???] Peak bit-rate : 9583200 bits/sec
15:13:34: INFO: [???] BUFFERING min 15 Buf max 211361
15:13:34: INFO: [???] AUDIO_STATISTICS: bd
15:13:34: INFO: [???] Audio stream length 302620416 bytes.
15:13:34: INFO: [???] Frames : 168873
15:13:34: INFO: [???] BUFFERING min 35 Buf max 6755
15:13:34: INFO: [???] MUX STATUS: no under-runs detected.
15:13:34: Done: Processing assets for DVD creation
Authoring DVD Folders
15:13:34: Creating TitleSet # 1
15:13:34: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
15:13:34: -->: DVDFolders creating VTS
15:13:34: -->: VTS 01
15:13:34:
DVD Folders: Processing C:\avimux\sling_S2D.mpg...
15:15:52:
15:17:26:
15:17:26: Finalising DVD...
15:17:27: SVCD2DVD: DVDfolders
15:17:27: -->: DVDFolders creating table of contents
15:17:27: scanning E:\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
15:17:27: Finalising DVD...Done
15:17:27: Done: Authoring DVD Folders
Burning DVD folder
15:17:27: Burning with ImgBurn...
16:11:00: Burning ISO...Done
16:11:00: Done: Burning DVD folder -
here is the 2.5 log
Title: 2.5
Version: 2.5.2713.16933
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2.5\%APPNAME%.EXE
Executable size: 2.58 MB
Executable size in bytes: 2711552
Executable CreationTime: 01/01/2000 00:00:00
Executable LastWriteTime: 01/01/2000 00:00:00
Executable LastAccessTime: 01/01/2000 00:00:00
Version : 5.1.2600
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Free Physical Memory: 1.36 GB
Free Virtual Memory: 1.96 GB
CPU Speed: 2.4GHz
CPU FSB: 200MHz
CPU Speed: 2.399GHz
CPU FSB: 200MHz
08:37:02: Logical CPUs: 2
Video Ram: 128 MB
Status: OK
DeviceID: C:
FileSystem: NTFS
FreeSpace: 75.3 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 75.3 GB
DeviceID: G:
FileSystem: NTFS
FreeSpace: 212 GB
<SVCD2DVD DateTime="11/06/2007 08:37:17" Filename="NONE"><AssetSet><Asset ID="ef8350dd-3811-44e3-b84b-6b72688e9034" Path="C:\avimux" Filename="sling.avi" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="53" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="sling.avi" AssetID="ef8350dd-3811-44e3-b84b-6b72688e9034" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2.5\default.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="" InitialDVDFolder="E:\" InitialProjectFolder="E:\" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Custom_ac3" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="ac3" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="ImgBurn 2+" ImgBurnPath="C:\Program Files\ImgBurn\ImgBurn.exe" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
File Size: 697 MB
file=C:\\avimux\\sling.avi
FormatName=avi
Num_Frames=129566
DurationInSecs=5404
Duration=01:30:04.0
VideoCodec=mpeg4
VideoFFSTNum=0
Width=624
Height=352
BitRate=1082
AudioStreamCount=1
Audio1FFSTNum=1
Audio1Codec=mp3
Audio1BitRate=32
Audio1Channels=2
08:37:17: Looking for AVI PAR...
08:37:19: FFmpeg version SVN-r8597, Copyright (c) 2000-2007 Fabrice Bellard, et al.
08:37:19: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-liba52 --enable-gpl --enable-libdts --enable-libfaad
08:37:19: libavutil version: 49.4.0
08:37:19: libavcodec version: 51.40.2
08:37:19: libavformat version: 51.11.0
08:37:19: built on Apr 4 2007 18:02:17, gcc: 4.3.0 20061204 (experimental)
08:37:19: Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/2733) -> 23.98 (10000000/417083)
08:37:19: Input #0, avi, from 'C:\avimux\sling.avi':
08:37:19: Duration: 01:30:04.0, start: 0.000000, bitrate: 1082 kb/s
08:37:19: Stream #0.0: Video: mpeg4, yuv420p, 624x352, 23.98 fps(r)
08:37:19: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 32 kb/s
08:37:19: Output #0, dvd, to 'C:\avimux\sling_S2D.mpg':
08:37:19: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=1-31, 6264 kb/s, 23.98 fps(c)
08:37:19: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
08:37:19: Stream mapping:
08:37:19: Stream #0.0 -> #0.0
08:37:19: Stream #0.1 -> #0.1
08:37:19: Press [q] to stop encoding
08:37:19: Compiler did not align stack variables. Libavcodec has been miscompiled
08:37:19: and may be very slow or crash. This is not a bug in libavcodec,
08:37:19: but in the compiler. Do not report crashes to FFmpeg developers.
09:15:04: video:3778160kB audio:295528kB global headers:0kB muxing overhead 2.057598%
09:15:05: AVI2MPG: done.
09:15:09: FFmpeg version SVN-r8597, Copyright (c) 2000-2007 Fabrice Bellard, et al.
09:15:09: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-liba52 --enable-gpl --enable-libdts --enable-libfaad
09:15:09: libavutil version: 49.4.0
09:15:09: libavcodec version: 51.40.2
09:15:09: libavformat version: 51.11.0
09:15:09: built on Apr 4 2007 18:02:17, gcc: 4.3.0 20061204 (experimental)
09:15:09: Input #0, mpeg, from 'C:\avimux\sling_S2DNTSC(Film).mpg':
09:15:09: Duration: 01:30:03.0, start: 0.500000, bitrate: 6303 kb/s
09:15:09: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480, 9000 kb/s, 23.98 fps(r)
09:15:09: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, stereo, 448 kb/s
09:15:09: Output #0, rawvideo, to 'C:\avimux\sling_S2DNTSC(Film).mpv':
09:15:09: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=2-31, 9000 kb/s, 23.98 fps(c)
09:15:09: Output #1, ac3, to 'C:\avimux\sling_S2DNTSC(Film).ac3':
09:15:09: Stream #1.0: Audio: ac3, 48000 Hz, stereo, 448 kb/s
09:15:09: Stream mapping:
09:15:09: Stream #0.0 -> #0.0
09:15:09: Stream #0.1 -> #1.0
09:15:09: Press [q] to stop encoding
09:20:36: video:3779598kB audio:295528kB global headers:0kB muxing overhead -7.251991%
09:20:36: NTSC(Film)->NTSC: Applying Pulldown sling_S2DNTSC(Film).mpv
09:20:36: SVCD2DVD: Convert2NTSC: Converting....
09:37:19: NTSC(Film)->NTSC: Muxing sling_S2D.mpg
09:44:27: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
09:44:27: INFO: [???] File C:\avimux\sling_S2DNTSC(Film)_pd.mpv looks like an MPEG Video stream.
09:44:27: INFO: [???] File C:\avimux\sling_S2DNTSC(Film).ac3 looks like an AC3 Audio stream.
09:44:27: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
09:44:27: INFO: [???] Found 1 audio streams and 1 video streams
09:44:27: INFO: [???] Selecting dvdauthor DVD output profile
09:44:27: INFO: [???] Multiplexing video program stream!
09:44:27: INFO: [???] Scanning for header info: Video stream e0 (C:\avimux\sling_S2DNTSC(Film)_pd.mpv)
09:44:27: INFO: [???] VIDEO STREAM: e0
09:44:27: INFO: [???] Frame width : 720
09:44:27: INFO: [???] Frame height : 480
09:44:27: INFO: [???] Aspect ratio : 16:9 display
09:44:27: INFO: [???] Picture rate : 29.970 frames/sec
09:44:27: INFO: [???] Bit rate : 9000000 bits/sec
09:44:27: INFO: [???] Vbv buffer size : 229376 bytes
09:44:27: INFO: [???] CSPF : 0
09:44:27: INFO: [???] Scanning for header info: AC3 Audio stream 00 (C:\avimux\sling_S2DNTSC(Film).ac3)
09:44:27: INFO: [???] AC3 frame size = 1792
09:44:27: INFO: [???] AC3 AUDIO STREAM:
09:44:27: INFO: [???] Bit rate : 57344 bytes/sec (448 kbit/sec)
09:44:27: INFO: [???] Frequency : 48000 Hz
09:44:27: INFO: [???] SYSTEMS/PROGRAM stream:
09:44:27: INFO: [???] rough-guess multiplexed stream data rate : 9653896
09:44:27: INFO: [???] target data-rate specified : 10080000
09:44:27: INFO: [???] Setting specified specified data rate: 10080000
09:44:27: INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16022
09:44:27: INFO: [???] New sequence commences...
09:44:27: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
09:44:27: INFO: [???] Audio bd: buf= 0 frame=000000 sector=00000000
09:44:27: INFO: [???] STREAM e0 completed @ frame 129565.
09:44:27: INFO: [???] STREAM bd completed @ frame 168872.
09:44:27: INFO: [???] Multiplex completion at SCR=486344557.
09:44:27: INFO: [???] Video e0: buf= 47039 frame=129565 sector=01916726
09:44:27: INFO: [???] Audio bd: buf= 14336 frame=168872 sector=00150110
09:44:27: INFO: [???] VIDEO_STATISTICS: e0
09:44:27: INFO: [???] Video Stream length: 3870308240 bytes
09:44:27: INFO: [???] Sequence headers: 10798
09:44:27: INFO: [???] Sequence ends : 0
09:44:27: INFO: [???] No. Pictures : 129566
09:44:27: INFO: [???] No. Groups : 10798
09:44:27: INFO: [???] No. I Frames : 10798 avg. size 45286 bytes
09:44:27: INFO: [???] No. P Frames : 32392 avg. size 34324 bytes
09:44:27: INFO: [???] No. B Frames : 86377 avg. size 26273 bytes
09:44:27: INFO: [???] Average bit-rate : 5729200 bits/sec
09:44:27: INFO: [???] Peak bit-rate : 9936000 bits/sec
09:44:27: INFO: [???] BUFFERING min 15 Buf max 176279
09:44:27: INFO: [???] AUDIO_STATISTICS: bd
09:44:27: INFO: [???] Audio stream length 302620416 bytes.
09:44:27: INFO: [???] Frames : 168873
09:44:27: INFO: [???] BUFFERING min 35 Buf max 6979
09:44:27: INFO: [???] MUX STATUS: no under-runs detected.
09:44:27: Done: Processing assets for DVD creation
09:44:28: Creating TitleSet # 1
09:44:28: SVCD2DVD: DVDfolders
09:44:28: -->: DVDFolders creating VTS
09:44:28: -->: VTS 01
09:44:28:
09:47:19:
09:49:50:
09:49:50: Finalising DVD...
09:49:50: SVCD2DVD: DVDfolders
09:49:50: -->: DVDFolders creating table of contents
09:49:50: scanning E:\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
09:49:50: Finalising DVD...Done
09:49:50: Done: Authoring DVD Folders
Burning DVD folder
09:49:50: Burning with ImgBurn...
12:41:12: Burning ISO...Done
12:41:12: Done: Burning DVD folder -
Well to investigate this i will need to try out a few things on the same file. Can you email me and i will send you some ftp details for you to upload the file to?
I am still getting the lines with the new build, tried it with a new xvid this morning. 2.1 coverts the file with no lines
I'm left my PC encoding three separate videos from different sources. Did you use 1 or 2 pass?
I have sent you an email as i will focos on this today. Please can you get back to me?Originally Posted by thekingbeyondSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Nope SVCD2DVD doesn't use codecs....
tried both on this file, lines are there no mater what settings i use. Have tried clean install of os and another pc and a laptop.
Indeed - did you get the email?Originally Posted by thekingbeyondSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Was it an NTSC or PAL source? Mine were NTSCs. Have run some PAL & NTSC tests today using 1-pass. Would 2-pass make a difference?
got the email and have replied
i have tried pal and ntsc, I use 1 pass normally -
Hey guys,
This issue was not something that I was aware of until you flagged it... (too much time programming - not enough time chilling in front of my TV!) BUT it has been solved now. Thanks for the heads-up and the correspondence offline - which has enabled me to address it.
Please can you download the latest version and confirm this has gone away?
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
It shouldn't be - maybe there is an issue with your source file... Have you tried others?
The following registry patch will speed it up, if you feel speed is more important than quality...
speedup.regSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks ChrissyBoy but I'd rather stick with higher quality! It does appear to be slower though compared to 2.1 with the same source video? Short of doing a timed test, is there anyway to see the actual fps in 2.1?
Well i would certainly try the reg thing.... it will speed up x2 and i can't tell any quality difference...
I completed a 1-pass test with the new 2.5 + speed patch and it all looked and worked great! Do you have an un-patch so I can test the quality more between the two?
Just delete the FFMPEGDEFAULTS key from HKEY_CURRENT_USER\Software\Badger I.T.\SVCD2DVD 2.5
and then you will be back to the default.... Apply the reg file and you will be back to the "speed up"...SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
vhs with vertical lines
By spiritgumm in forum Video ConversionReplies: 29Last Post: 22nd Aug 2019, 09:17 -
Vertical lines in SD camcorder video ?
By Umen Pich in forum EditingReplies: 8Last Post: 21st Dec 2011, 19:25 -
Bizarre vertical lines
By Asterra in forum Capturing and VCRReplies: 55Last Post: 17th Apr 2011, 21:46 -
Vertical Lines from Video Camera
By solarblast in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2008, 21:30 -
Vertical Lines Appearing On Capture
By XBucklawX in forum Capturing and VCRReplies: 0Last Post: 26th Jun 2007, 11:11
looks like you got it sorted, got about 20 to convert so will post back if I get any problems
