Ok what I used to use was tmpgenc xpresw 4 and dvdlab pro to make dvds out of mkvs and ogms when i had windows xp but since i updated to windows vista now the version of tmpgenc xpress 4 doesnt work. What is a good program to encode to dvd mpeg files on vista without any quality loss?
Results 1 to 9 of 9
i tried convertxtodvd and with one file if i put the mkv in i get the full 28 minutes but the video is all choppy and green but if i extract the video out if the file before using convertxtodvd i get the video but it is 7 minutes.
the only reason i use them is that is the only way i can get the english and japanese audio and the subtitles
if the file was an avi file would convertxtodvd work and keep great quality
It would keep the quality as good as any one-click solution will. The best quality would be achieved by using avisynth or virtualdub, some appropriate filters, and a good quality mpeg2 encoder. Donald Graft has created some very good filters specifically for anime source. Of course, the process will take longer to set up, and longer to encode, and requires some effort on your part.
Read my blog here.
Where can i get these filters and possibly a step by step guide on how to use them?
Read my blog here.
Dealing with Anime DVDs
By tehslax in forum Newbie / General discussionsReplies: 4Last Post: 28th Nov 2010, 15:06 -
Converting Anime DVDs to AVI (AutoGK)
By vangelon in forum DVD RippingReplies: 6Last Post: 18th Nov 2009, 03:25 -
Anime Encoding From DVDs to h264.
By kwanbis in forum Newbie / General discussionsReplies: 9Last Post: 11th Mar 2009, 19:31 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 15:31 -
Making one DVD from 2 DVDs
By asadfx in forum Newbie / General discussionsReplies: 3Last Post: 15th Dec 2007, 19:51
