How to make a piece of CD R be multisessional
It means i can burn / add files into this CD R again and again.......
And can i edit or replace the existed file in a burned CD R?
if possible, how ?
				Results 1 to 11 of 11
	Some burning apps let you do this, but not all.
 For instance Nero gives you this option when you create a data disc. (see below).
 So does Fireburner. I don't know of any free software that does though.
 But you can't edit or replace files once you've burnt it.
 (You can use a CDRW with packet burning software, like InCD, but that's a different format.)
	Well , to be compliant , you import the previous burnt session first .
 From here , if a file is about to be replaced with the updated version or same name in use , you get a warning .
 Yes if action is correct (replacing it with updated file) .
 No , either review situation or place it in a new folder and continue .
 Continue using multisession in the same manner , but remember when disc is nearing capacity , to import last session , add files and close the cd (finalize) , in order for any pc to view the content .
	For CD-R multi-session, if you do it correctly, you CAN make the CD-R appear to have "erased" or "edited/updated" a file. In actuality, the original file is either left unlinked in the new session altogether (erased) or linked to a new and different additional file (edited/updated). An app like ISOBuster --could-- pick any one of those sessions and files to extract, so it's not truly erasing/updating like on a hard drive.
 Most every even 1/2way decent burning app can do multisession. You just have to tell it up front at the beginning that that is what you want, and then you have to import the last session (every time you start a new session).
	I feel that I should warn the original poster that multisession discs almost never play back correctly in standalone devices. This includes DVD players and CD players. Usually what happens is such devices only see whatever was part of the first session. As a result, I don't recommend that anyone make such discs unless they only intend to use them on PCs as PCs seem to be the only thing that always plays them correctly.
	okOriginally Posted by AlanHK
 i use nero
 and ive check that box
 but still i cant make my cd r multisession
 how come?
	how to make it correctly without the software u mentioned?Originally Posted by Cornucopia
 im a newbie to these
	If you click that button, it IS multi session, until you "finalise" it.Originally Posted by xiaofan
	Type "finalize" into Nero's help index.Originally Posted by xiaofan
  New problem with multisession DVDsBy SteveO_29 in forum Newbie / General discussionsReplies: 20Last Post: 22nd Jan 2011, 15:20
  Two questions on multisession recorded disksBy perfection in forum Newbie / General discussionsReplies: 2Last Post: 21st May 2010, 05:33
  Will Nero 7.0 do a Multisession DVDBy scustalow in forum Software PlayingReplies: 6Last Post: 1st Oct 2008, 13:16
  NERO can not keep a Data CD Open- no multisessionBy src2206 in forum ComputerReplies: 4Last Post: 19th Aug 2008, 15:23
  Closing Multisession tracks?By When in forum Authoring (DVD)Replies: 9Last Post: 30th Jul 2008, 05:15
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
