    Jun 2007
    Canada
    I have made a couple of hidden menus in GUIforDVDAuthor. By hidden I mean they are buttons with no text, the arrow key can navigate to them, but nothing highlights. I am doing this for an Easter Egg effect. However, how can I stop the skip button on the dvd remote from skipping to the next video clips?
    Thanks,
    -Kevin
  2. If you are using MuxMan as authoring engine, you can set UOPs (not allowed operations). If you use dvdauthor, you have to set the UOPs afterwards with pgcedit.
