Just got a new iPod with video and wanted if there is a good freeware program that converts DVDs to the iPod format.
Try SUPER. If it works for you, good.
The best tool, I don't know.
You may have to decrypt the DVD with a program like DVDFab Decrypter and convert the decrypted DVD to one large MPEG with VOB2MPG first, but there are no quality losses with that. All those programs are freeware.
I tend to recommend Videora iPod Converter over SUPER, at the moment... but I haven't tried the new 2.x versions, yet. (My sister's the one with the 5G iPod, and I haven't had any reason to convert videos for it, for a while.)
Edit: Oops, I forgot to mention... yes, I know Videora isn't an all-in-one ripping and converting program. And I'm not sure if it'll accept VOB files as input. But, to my knowledge (and as redwudz mentioned above), none of the free options include a ripper (one that'll work with protected DVDs, at that), so you'll likely need another program to do that, anyway.
And (personally), I'd rather convert VOBs to AVI using AutoGK (or convert them to MPEG using VOB2MPEG) than feed them to SUPER, and use the result with Videora. (Not that I'm putting down SUPER.)If cameras add ten pounds, why would people want to eat them? -
I also vote for Videora iPod Converter. Super is great but quality wise is always second!
O.T.: If I find a way to batch convert x264 with virtualdub, I won't use Super for a long - long time... Does someone has a solution for this? -
Today until 12:00 PM, there is a free program that will convert videos. I have not tried because I do not have an iPod. I suggest that you read the comments first.
http://giveawayoftheday.com
Always "run as administrator" the activation and setup file if you are using Vista (don't know about XP). -
Use a chain of apps -- DVDFab Decrypter, DGMPGDec, AviSynth, and ffmpeg. All free and tons of flexibilty. Not a "one-click" solution but will give best results.
does Videora work for SanDisk Sansa?I don't have one but I'm thinking about buying oneOriginally Posted by SatStorm
Seeking Rec for convert tool, w/ some editing, need not be freeware
By davbol in forum Video ConversionReplies: 6Last Post: 7th Jan 2011, 16:28 -
newbie question: need freeware DVD authoring tool
By kbflower in forum Authoring (DVD)Replies: 7Last Post: 20th Jul 2008, 21:45 -
Best freeware tool for converting .flv to ipod compatible fromat?
By xoADAMox in forum Video ConversionReplies: 5Last Post: 10th Jul 2008, 10:31 -
Found an excellent freeware DVD copy tool...
By Djard in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2008, 20:17 -
Looking for a tool to convert .ISO to the ipod format.
By xoADAMox in forum Newbie / General discussionsReplies: 4Last Post: 19th Jun 2007, 01:10
