    Jun 2007
    South Africa
    i edited a movie with virtualdub,i added a few filters,but somehow when i view the endproduct i see the filters in the movie,why is this?what happened?
    USA
    What filters did you use and what do you see in the finished video? Some payware filters leave visible watermarks if you are using the trial version of them. Divx may display a watermark also, but you can turn that off in the codec settings for playback.
    And welcome to our forums.
    Jun 2007
    South Africa
    well it looks like watermarks,tommorow i'll post some screenshots,the filters i used are for removing noise,they all built into virtualdub,so how do i turn off the divx watermark,that u mentioned?so what else can be wrong?
  4. Mod Neophyte redwudz's Avatar
    USA
    For DivX, go to DivX in your program menu>'DivX Codec>Decoder Configuration Utility>Toolbar' then uncheck 'Show DivX logo watermark'.
    I can't think of any default VD filters that leave any watermarks, except Logo for adding a image.
    Jun 2007
    South Africa
    u can see the blocks made by the deblocking filter,now one problem the movie is a porn movie,will they allow the screenshots?
    Jun 2007
    South Africa
    it seems divx was part of the problem
