I've just built a new machine with the following specs:
Athlon XP 1900+
Epox 8Kha+ with Via KT266a chipset
1.5 GB High performance RAM
IBM 75GXP Deskstar 75 GB UDMA IDE drive
Soundblaster Audigy Platinum
Plextor 24/10 CDR/W
Toshiba 16x DVDRom
I'm temporarily using an old Geforce2 Ultra vid card in it because I'm not exactly sure which capture card to get. At first I was thinking I would get one of the new ATI AIW Radeons, but after doing some extensive reading here, I've changed my mind and now I'm trying to figure out which of the following would be the best:
Dazzle DVC II
Dazzle Hollywood DV-Bridge
Or perhaps something I've overlooked. I don't have a digital vid camera...yet. I do plan to get one eventually, but I'm looking to record programs directly from TV in high-quality format for later archiving to CD. I also have several home vids that I want to convert to VCD or SVCD.
Anyway any help is appreciated!
Dazzle Hollywood DV-Bridge is Good But if you are more serious video capture and Editing go for the Pinnacle System DV500+ I have one and is Awesome.
Feel my Power Flaming Black Dragon Wave!!!! -
I know some people haven't, but I have been very happy with the ATI AIW Radeon 32DRR. With tools out there like Stinky's Reg Tool, great VCD capture quality is possible. But this is my first capture card and I can't speak for or against others.
TheNob -
As already mentioned the Dv Bridge is very good...... You will need alot of hard disk space for the capture file ! - The DVC2 is also a very good capture card.... allowing capture in 'Real=Time' to VCD SVCD & DVD (Amongst other X settings) ..... The choice is yours at the end of the day... I would personaly go for the DVC2..... :P
Hiei,
I read through the user comments on the Pinnacle and someone mentioned something about a problem doing DVD conversions because of a spike or something in the data. Is this a problem?
The only kind of editing I might be doing is getting rid of commercials and such, but probably nothing really high tech. It is quite a price difference as well. I'm not adverse to spending $550, I just wonder if it's worth twice the price of the DVCII.
Thanks!
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
