Hello people, I'm new here, I just wanna ask you something.
As you guys can read the title, i wanted to ask you if there is a way to erase some parts of a videoclip (like the Erase tool found in Photoshop for example, and, obviously, without erasing the part frame per frame, but once) so to show the video that is below? So the erased part remains transparent and the rest of the clip continues to show.
I've tried with Flash but u can only "mask" the video, u can't make a part of it "transparent".
Thanks in advance.
Fr4nk
Results 1 to 11 of 11
You might want to try "Track Masks" if the area that you want to make transparent is pretty static.
I recently made a video tutorial on Track Masks editing with Vegas. look it up in the guides section, if your interested.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I'm not sure if flash supports alpha. Alpha is the transparency component for each layer in a composite. Mask is a separate way to show or hide a portion of the frame.
It's not very clear what you are trying to accomplish. I'm assuming that A)you already have a video and B)it has a regular background of varying colors and images that you want to remove.
Is that what you're tryig to do?
You can do this but its a very long process and would require a tremendous amount of work. -
Now i explain better:
1) I wanna cut a part of a video, an HEAD for example, and put it on another one.
Is that so hard? I remember that there were softwares that allows you to cut a region of a video, and save it somewhere
2) I wanna just cut a video region so it becames a "mask" for the other video that is below.
Have I been clear now?
Yes it is, cutting a region and cutting a head are two different things, a head is going to have movement unless your subject is absolutely still hence the reason they you use choma keying. As I mentioned above you can do this but it will be a very long process, doing it in photoshop is simple because you only have one image to deal with. With video you have 30 frames a second.Originally Posted by fr4nk
I don't have Vegas so I couldn't even begin to tell you where to start. -
"Masking" in compositing, is the process of using a controlled selection to set transparency levels in a layer.
For layers that already have alpha channels, the Alpha channel is usually the mask.
For layers without alpha, you have to define the selection...
A fairly quick/automatic way is to use Keying (Chroma or Luma), which bases transparency on Color value(s) or Light value(s) respectively.
Problem is, these are usually ALL or NOTHING threshold processes, and so you have to get that threshold just right.
You can also create Mattes (cutouts), based on Standalone greyscale still or video clip layers. These could be created through Bezier path drawing, or some other feature selection.
And sometimes you can do a combination of all the above.
Scott -
In the pro world you have the luxury of alpha (usually used to define object edges) for each input and one or more masks assignable for each layer of the composite.Originally Posted by Cornucopia
These guys should pay their employer to work there.
Just kidding.
Complex chroma key matting problem
By Morality124 in forum EditingReplies: 33Last Post: 7th Nov 2010, 16:36 -
Can Premiere CS4 do quality chroma key? I can't
By MAtkins in forum Newbie / General discussionsReplies: 35Last Post: 26th Mar 2010, 03:49 -
My first attempt at a bluescreen chroma key
By CogoSWSDS in forum EditingReplies: 4Last Post: 16th Apr 2009, 23:11 -
Vegas adding video overlays using chroma key
By SearchQuality in forum EditingReplies: 12Last Post: 14th Dec 2007, 18:12 -
Chroma Key workflow for large number of clips
By pablogott in forum MacReplies: 0Last Post: 27th Jun 2007, 20:21
