  1. I have a ASF file of a Madonna Concert broadcast over MSN last year. The quality is really good so I figured I could either make a AVI or MPEG-II file out of it to burn on DVD-R or VCD at a later date. I tried to use TMPGEnc, however when I start to encode it with the VCD template it says remaining time is like 3 days. Is this usual for ASF files?
    Barney
    My system is a P3 933 Mhz with 512 Megs RAM
    Ok Ok Ok, I know I'm not as smart as all of you. But look how much smarter I make you look!
  2. Get this freeware tool from http://www.geocities.com/myasftools/. Use it to help in the conversion of your file. Sometimes it works sometimes it doesn't. Use a version of virtual dub to convert the file to .avi.
  3. Hey Damnim, thanks alot! I did try this program, but for some reason after it converts to AVI it tells me that the file is WVM7 and the AVI might not play correctly. When I try to play the AVI back in Windows Media player it tries to download the codec, and after it downloads the codec it says file type unsupported. When I try to and the AVI into TMPGEnc it also claims the file unsuported. think it's because it's in a unusual aspect ration. Not 19:9 not 4:3.
    Barney
  4. you have to get a older version of virtual dub,you can get it at the doom site
    Dec 2001
    Australia
    get Virtual Dub 1.3c open your asf up, and click file and go frameserve
    (there is a how to frameserve on vcdhelp.com) and then load up tmpgenc and encode..
    check out the tutorial on how to frameserv
    works for meh
