Probably nothing. Most DVD players will play both nowadays.
Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh? -
Originally Posted by mhar4
You will need to convert your PAL video to NTSC video by 1) changing the framerate and 2) changing the resolution. This can get messy if your source video is interlaced.
I often convert PAL movies to NTSC using ffmpeg.
Code:ffmpeg -i moviePAL.vob -target ntsc-dvd -aspect 16:9 -acodec copy movieNTSC.mpg
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 09:40 -
Big video project with NTSC and PAL-material
By garylanders in forum Capturing and VCRReplies: 0Last Post: 3rd Jul 2011, 07:09 -
Sony Hi8 (PAL) pass-through to Canon (NTSC) - will this work?
By frappefan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Dec 2010, 13:18 -
will a NTSC sony FX1 work in australia were we use PAL?
By gogofilms in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Aug 2009, 17:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43
