    Jun 2007
    Netherlands
    Hi all, been looking for a fast encoder been using Divx Converter as I like uploading vidoe's you YouTube but it tends too take too long and was wondering is there a good video encoder that can also make me decide the file size ( like Divx Converter ) but one that works faster ? thx alot.
    You could try Autogk or Dr.Divx. But I don't think you will get that much speed improvement. Another method would be to use a gui for mencoder or ffmpeg like Super, WinFF. Or convert to another video format, mpeg1 encoding is faster.
    Or get a faster computer.
    Jun 2007
    Netherlands
    Thx.. btw its not about my PC it just takes long..
  4. Member ricardouk's Avatar
    Mar 2005
    Portugal
    if you´re uploading the output of divxconvert that is mpeg2/dvd it will take a long time unless you have a super high fast internet connection. a 5 min dvd will take as much as 100 mg. Uploading 100 mg to youtube does take a lomg time.
    I love it when a plan comes together!
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    What takes time?? the conversion or uploading?????
  6. Conversion is all about the computer. The faster the computer the shorter the encode time.
    Want to speed it up. Get a fast dual core Cpu and a second hard drive. encode from one drive to another physical drive not just one drive partitioned.
