hi e1, Im new to this but hav lot's of hope's
I want my friend to c what iam doing here on my desktop. In fact i hav explain him how to wrk on a software. My frend is very new to comp n hence he can use only internet Browser.( He is in my lan and i Hav http server on my comp)
kindly give suggestions.
Also if any1 who cud give wat is encoding?? when its to be done?? b4 straming/after??
sooner replies are appreciated.
Something like http://beamyourscreen.beamyourscreen.qarchive.org/ or or a vnc software with view mode like http://www.uvnc.com/ .
Thnq vry much, above mentioned are utilities which would accomplish my task.
But can u please tell me how can i achieve it by myself using encoder,streaming, and web server to my site.
step by step expln is definitely required.
sooner replies pl. -
http://www.beamyourscreen.com/EU/HowItWorks.aspx
(free trial available for testing) -
I meant how to webcast on my own instead of depending on utilities and all
Q: He is in my lan
Screen = windows media encoder
Chat = interchat : http://www.snapfiles.com/get/interchat.html
They can see and chat on lan when needed , simple
Wme , I use pull (client side) , rather than push .
Windows media player , file , open , enter url as specified .
Internet , connect to is http:// ip address
ort (dont forget port needs to be opened in firewalls)
Lan , connect to is http:// encoding computers name on lan
ort
Works well , but issues with multiple apps running on same pc may slow it down .
You can save streaming media while your doing it , just incase they want to repeat anything later .
Vnc has security issues , but I have not tested it for lan use yet , only for bussiness , long distance quick fix's for customers , but if its hardware failure on their end , its get in the car and go there .
Audio Video Broadcast using VSAT TDM/TDMA
By naburju in forum Video Streaming DownloadingReplies: 0Last Post: 20th Oct 2011, 00:27 -
Is there a way to see actions done by scripts?
By Marc01FR in forum ffmpegX general discussionReplies: 1Last Post: 21st Jan 2011, 15:27 -
DTV broadcast audio all over the map?
By ahhaa in forum DVB / IPTVReplies: 3Last Post: 16th Jan 2009, 23:52 -
Re: how does video affect audio in broadcast?
By edDV in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 20:50 -
Audio doesn't broadcast in WME
By versionII in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 11:40
