I am using Dazzle DVII to capture my video in MPEG 1 22mbs, after extensive testing I found this to be pretty decent quality. I have tried to capture in MPEG 2 but my version of Nero does not allow me to convert to VCD (have to purchase an upgrade).
after capturing the video I use Nero to drag n drop into VCD. This seems to work fine on an individual file basis. If I try to drag more than 2 then Nero seems to hang in the encoding process at about 30-50% completion?
any suggestions how to fix this problem? I have tried TMPGEnc and VCDEasy but I like Nero for the simplicity.
question: I captured in MPEG1 and VCD is MPEG1, why do I need to encode? Isn't the MPEG file already in its proper format?
even if I capture in VCD format I find that Nero still wants to re-encode?
DE-SELECT (In NERO) the "Make standard Compliant VCD" .... Nero wont re-encode your high Bit Rate Mpeg 1 file now
Yep, you got it Bud. The deselect is on the first main tab when you open the s/v/cd Creator dialogue
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
Creating MP4 or DVD from an .avi and a .srt file using Nero 10
By criggs in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2011, 02:04 -
Error creating VCD
By maruz in forum ffmpegX general discussionReplies: 4Last Post: 17th Oct 2009, 06:42 -
Nero vision VCD autoplay
By Aliyans in forum Authoring (VCD/SVCD)Replies: 8Last Post: 31st Dec 2007, 10:54 -
Creating (S)VCD Stills with Audio
By Cornucopia in forum User guidesReplies: 8Last Post: 4th Aug 2007, 12:05 -
consolidate vcd files with Nero Vision, but problem with playback
By slh888 in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2007, 17:36
