    Jun 2007
    Take a look and see if you can help. Thanks!
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Mac OSX universal build for ffmpegX
    libavutil version: 49.0.0
    Wed Jun 6 17:04:37 PDT 2007
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    Seems that stream 1 comes from film source: 1000.00 (1000/1) -> 23.98 (24000/1001)
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/PROJECTS/Ashtray/ashtrayweb.mov':
    Duration: 00:01:21.7, start: 0.000000, bitrate: 6480 kb/s
    Stream #0.0(eng): Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
    Stream #0.1(eng), 23.98 fps(r): Video: mpeg4, yuv420p, 720x480
    Output #0, flv, to '/PROJECTS/Ashtray/ashtrayweb.mov.ff.flv':
    Stream #0.0, 23.98 fps(c): Video: flv, yuv420p, 720x480, q=2-15, 1861 kb/s
    Stream #0.1: Audio: mp3, 44100 Hz, stereo, 128 kb/s
    Stream mapping:
    Stream #0.1 -> #0.0 [sync #0.0]
    Stream #0.0 -> #0.1 [sync #0.1]
    bench: utime=34.370s
    video:4898kB audio:1278kB global headers:0kB muxing overhead 171.076549%
    Encoding completed on Wed Jun 6 17:05:18 PDT 2007
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    It looks like you are trying to convert to flv. What tool(s) are you trying to use? Does the original file play ok?
    This is most likely a tool/conversion issue...but we need more info.
    Google is your Friend
  3. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Originally Posted by calthorpe
    FLV playback stutter
    The playback stutter seems to be related to ffmpeg's stream mapping.
    For conversions without inverted mapping, the output is as smooth as the set framerate allows,
    but whenever the mapping is inverted, you'll see the stuttering like it is only doing 2 frames per second.
    The same thing happens in ffmpegX GUI as in the Terminal with the ffmpeg from inside the package.
    Looks to me like a bug in the ffmpeg binary.
    No idea why this behavior only shows with output to FLV.
    Feb 2008
    Hi Case,
    I'm having the same problem with flv playback stutter. Forgive my ignorance, but is there a setting that needs to be changed in order to add "inverted mapping?" Or, should I be using another program to convert from .mov to .flv?
    Thanks for your help,
    Jamie
  5. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Sort of. You can reverse the stream order with QuickTime Pro to make the source file acceptable for ffmpegX without inverting the mapping.
    https://forum.videohelp.com/topic341561.html#1810515
    I've asked the developer to look into it, so hopefully this is a temporary hack.
    Oct 2008
    Has this issue been fixed... Just wondering before I buy Quicktime Pro - I have the same issues with stuttering. Thanks!
  7. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Not yet.
