I am using BEYOND TV to record HDTV programs as .tp files
I convert these .tp files to mpg with HDTVtoMPEG2
This .mpg is still of HD quality.
I would like to retain this HDTV quality video, but convert the .mpg to .vob...in other words, I want to burn my BEYOND TV HDTV programs to standard dual layer DVDs for playback on any ol' home DVD player.
I understand the size of files/length of program issues.
Is there a software program that can do this? SVCD2DVD just isn't getting it done.
I am using VISTA on a dual Centrino laptop at 1.87 ghz per processor.
Please help.Kevin
HD isn't supported for DVD VOB
Max resolution is 720x480/576 -
This is a Newbie forum....I'm not sure what you're saying.
Dumb-it-down for me. -
DVD is maximum 720x480. See
https://www.videohelp.com/dvd
Your HD file would need to be downsized from 1920x1080i or 1280x720p to wide 720x480i/29.97 or wide 720x480p/23.976 and bit rate needs to fit spec as well. A good program to do this for you is ULead Movie Factory 6 or you could go step by step with other programs. -
So...is the bit rate and video size limitations I've been running into (including ULEAD MF6, which won't ever accept the higher rates/sizes in the preferences dialog box) a by-product of the software or the nature of VOB?
If I'm understanding you, the problem lies in the /vob technology?...it can't BE that big? -
DVD is standard definition and has strict definitions as to how files are prepared.
For high definition formats see
HD DVD
BluRay DVD
https://www.videohelp.com/hd -
Thanks.
I learnt sumthin' today.
I appreciate the time, edDV
Kevin
HDTV to DVD - How To?
By JoRodd in forum DVB / IPTVReplies: 4Last Post: 21st Jan 2009, 19:55 -
Do Samsung HDTV's have an RF antenna connector for receiving off-air HDTV?
By pianopeddler in forum DVB / IPTVReplies: 2Last Post: 6th Aug 2008, 21:43 -
Need al little help getting my new ati hdtv pci card to sense HDTV channels
By MidnightMike in forum ComputerReplies: 8Last Post: 23rd Jul 2008, 02:12 -
Problems with connection with my Panasonic HDTV and Timewaner HDTV box...
By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 22:39 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 00:32
