I tought a lot about which topic should I post this message in, and this one sounds to be the best to fit my needs. Sorry if it's not the right place.
I would like to replace an audio stream of a DV AVI (Microsoft DV) file with a Wave file. I used to do it with Steinberg's Nuendo. It has a feature "replace audio in video". But now i have to replace many files and more often. Since in Nuendo is't done one-by-one thigs get a little compicated
I searched web for something like that, bus all of the tutorials are about replaceing audio streams in DVDs.
Can anyone please recomment me some tool (preferably command line) that would allow me to replace an audio stream (uncompressed) of DV AVI (Microsoft DV) with the other uncompressed WAVE file?
Thank you.
VirtualDub. Direct stream copy the video and select your alternate audio then save as avi.
Buy My Books -
I use VirtualDub Mod, as I prefer the way it handles audio. The regular VD is a little convoluted. With VDM, you just add the new audio to the stream list, disable the old audio and select direct stream copy for the video and audio. It doesn't take long to produce the muxed file.
If VD or VDM doesn't open it, you may need to add a DV codec like the Cedocida DV Codec, Canopus DV Codec or the Panasonic DV codec. And there are many guides to using VD or VDM at the bottom of their toolpages. <<<<<<
And welcome to our forums.
I don't care if you prefer VDubMod, but there is nothing convoluted about the regular VDub. What could be simpler than Audio\Wav Audio, select the new audio file. By default Direct Stream Copy is already selected so you only have to set the video to Direct Stream Copy and Save AVI. Also, I believe the latest versions of VDub do not require installing an additional DV codec. VdubMod probably does because it hasn't been kept up to date with the standard version.Originally Posted by redwudz"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books
No sound from a PCM audio stream using DVDFab DVD to AVI file.
By loninappleton in forum AudioReplies: 8Last Post: 5th Dec 2011, 04:27 -
replace audio in a avi file.
By bigjohnny002 in forum AudioReplies: 9Last Post: 6th Dec 2009, 01:11 -
Replace audio DV AVI
By Abas-Avara in forum EditingReplies: 11Last Post: 19th Sep 2009, 16:54 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27 -
How-to replace the audio on an AVI file
By WuTangDvD in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2007, 13:03
