I really need help changing the framerate in VirtualDubMod. I'm creating a timeshifted road movie. I've been trying all kinds of settings at Video/Framerate, but I can only get the movie down to half it's lenght in time. Input is 15 FPS XVID. Can you please suggest me framerate settings? Thanks.
The goal is to reduce 30 hours of video to an hour, or something like that. Madonna - Ray of light, and all that.
I prefere VirtualDubMod but if you have suggestions for other freewares to do this, please share.
Thank you for helping!
Go to the Frame Rate dialog in VirtualDubMod:
In the top section, Source rate adjustment, set "Change to [900] frames per second". Or 30 times the final desired frame rate. This is telling VirtualDubMod to ignore the frame rate, pretend it's 900.
In the middle section, Frame Rate Conversion, set Convert to [30] or whatever frame rate you want in the resulting file. This is telling VirtualDubMod to reduce the frame rate from 900 to 30. It will throw away 29 out of every 30 frames leaving you with a 30 fps video.
I just noticed that VirtualDubMod won't allow you to specify a frame rate over 200 in the top section. Newer versions of VirtualDub do though.
A possible workaround for VirtualDubMod: leave the top section at the default 15 fps. Change the middle section to 0.5 fps. Save your file. Use AVIFrate to change the AVI files frame rate from 0.5 to 30.
How Can I Playback Video Really Fast?
By AlexBarclay in forum Software PlayingReplies: 5Last Post: 1st Sep 2014, 11:45 -
super fast way to resize video
By anafam in forum EditingReplies: 9Last Post: 28th Mar 2010, 08:44 -
Avisynth video playback twice as fast
By honza.v in forum Video ConversionReplies: 2Last Post: 3rd Jan 2010, 09:58 -
Framerate Changing to 30.1328?
By tacman1123 in forum EditingReplies: 0Last Post: 22nd May 2008, 15:22 -
Changing the framerate during conversion
By 2nickelstripper in forum Video ConversionReplies: 2Last Post: 7th Dec 2007, 08:46
