Hi
I've just picked up a new TV tuner for my system and hooked it up. I tried installing Btwincap drivers because I heard they were good. Unfortunately, it didn't work and I decided to stick to the Leadtek drivers. This ended up being even worse as I wasn't able to even install them - the installation window would come up and then a splash screen later, everything would just go. I downloaded the new drivers online and wasn't able to get the card to work with those either - the PVR software just said no capture device found.
After a few hours of tinkering, I managed to get the card working on the btwincap drivers. I have two problems though. Which program would be the best to capture? I tried VirtualVCR, and while that works great, the signal quality is awful. Its got a weird hissing sound to it and not very clear. I checked the signal using DScaler and it was only a little better - but DScaler allowed me to fine tune the channels so I get a good picture. Can anyone suggest a good capture program?
Also, i connected to the line out of my card to the line in on the on-board sound card. Is this the cause of the weird hissing noise? It doesn't come on all channels, so it could also be down to fine tuning.
Cheers!
Results 1 to 1 of 1
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 12:32 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 10:05 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 13:01 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 12:00
