I'm not sure what else to make of this. I have tried to create a DVD, but when starting the burn process it fails at 1%. I have attached a log file from Nero. Please can someone advise me.
Thanks in advance.
Frankly I'd advise you not to use Nero to burn a DVD.
No offense against Nero, I love version 6 for CDs, but that's about it.
Try imgburn and imgtools (freeware!). I took a glance at your log but, again as a Nero fan, it's not worth the coasters trying to figure out where the problem is when imgburn will do it.
EDIT: You've got a heck of a lot of serial numbers in there. Could be that a few of them are ... uh ... unauthorized ...
This Nero version is from a disc that I got with my computer. As for the serial numbers, I haven't got an idea, prob codecs ?
Codecs ......
that is humor .....
calling serial numbers codecs........ thanks -
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Disc Manufacturer: MCC 03 - RG20 (You can look up this media code to the left in 'DVD Media')
Try some different media, that's the easiest thing to change. But if you have a lot of that media, try ImgBurn. If it doesn't work, then a media change. -
Yeah? Go and split elsewhere then.Originally Posted by bendixG15
The point being, it was already stated they were serial numbers...and there should only be one. Typically when posting logs you remove them so that no one can take/use your serial number. In this case, it doesn't appear to even be a vaild copy. Not that it matters, someone helped you anyway.Originally Posted by DuBsTaR
cheersGoogle is your Friend -
Of course it's a valid copy. The serial numbers that you see or cracks for codecs that I installed. Nothing more. I have the disc that I installed it from, just added codecs...that is all. I don't know why I'm explaining myself, that is not even the problem. I resolved my problem myself.
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
Windwos 7 fails burning Windows XP doesn't ...
By deepcut in forum Newbie / General discussionsReplies: 10Last Post: 4th Dec 2011, 07:33 -
SVCD2DVD and then burning with imgburn fails
By baby2003 in forum Authoring (DVD)Replies: 5Last Post: 7th Sep 2010, 14:57 -
Burning always fails at 98%...
By Variable in forum DVD & Blu-ray WritersReplies: 14Last Post: 29th Feb 2008, 16:45 -
DVR 633 fails to initalize when burning to DVD
By Howardlan in forum DVD & Blu-ray RecordersReplies: 5Last Post: 11th Nov 2007, 18:46
