I'm converting a tape to DVD that has audio from whatever it was taped over bleeding in and sometimes completely taking over the proper track. Is there ANY way to fix this or am I screwed? I'm guessing the latter but I figured I'd ask anyway.
Thanks!
I'm guessing you're screwed but maybe there's hope, depending on the audio tracks on the VHS -- is this a hi-fi tape, or a linear-audio-only tape? If it's a hi-fi tape you may be able to recover the audio from either the hi-fi track, or the linear track, and perhaps one of them has non-garbled audio. Kind of a long shot, though.
But worth checking out!
Also maybe the tracking on this deck is off just enough that -- assuming it's the linear audio tracks -- that maybe a different deck might not catch the "edge" of the previous audio track, and give you clean sound. Relatively speaking, that is -- linear audio tracks on VHS are nothing to write home about.
Anyway, I think it's definitely worth trying this tape on another deck. Maybe go down to your local video store and see if they'll let you try it out on a demo VCR? -
Hmm.
I do have some other VCRs I can test it on, but I already tried all of the "Audio Monitor" settings on my JVC 9800. -
Besweet can deal with that....
No software is going to help on this one. You need to try another deck and hope for the best.
Removing Colour Bleed ?
By Tafflad in forum EditingReplies: 14Last Post: 30th Aug 2011, 17:01 -
color bleed
By unclescoob in forum Newbie / General discussionsReplies: 11Last Post: 1st Aug 2011, 16:09 -
Chroma/Color Bleed Issues In MPEG2-->XviD Conversion
By onesikgypo in forum Video ConversionReplies: 8Last Post: 25th Jun 2011, 21:11 -
Colour Bleed filter for Virtualdub?
By SatStorm in forum RestorationReplies: 3Last Post: 11th Aug 2009, 06:27 -
Color Bleed on Hauppage WinTV-PVR 150
By TheBladeRoden in forum Capturing and VCRReplies: 3Last Post: 14th Jun 2007, 09:05
