is there a way to burn these to a dvd disk? what do u use to convert these to DVD?
You can burn a mkv file as data to a dvd disk... but this will not be playable on a standalone as far as I know...
To create a dvd for a standalone player I use the 'normal' tools: avisynth and ffdshow.
Ffdshow to be able to 'read' the mkv file and Avisynth to create the file to load into the mpg2-encoder (ie HC, TMpgEnc).
I always treat the audio seperately
Example avs:
directshowsource("myfile.mkv",audio=false)
Hope this will get you started
Good luck... -
can you be a little more specific, i want to burn a mkv movie file a dvd disc
There is a cheap n cheerful option
The "ever-popular" ConvertXtoDVD accepts MKV files and does all the hard work for you
Ideal if quality is not relevant and you don't have the time/patience/knowledge to use the 'normal' tools as above
(No disrespect intended to babiulep)Don't worry.......we'll be alright... -
MKV files are 'hairy' the cause lots of problems can be hard to work with
run it thru gspot an get the info, IS what size is the video resolution,if it its HD, convertx is not going to handle it,
try either super OR mkv extract, super might convert it ot mpeg2 whic you can then convert to DVD
or you can try MKV extract to get/extract the video stream & sound stream from the MKV container, then convert them with another tool
it either way it is likely to involve several steps to go from mkv to DVD -
is there a simple way of burning mkv files to disk so i can watch the movies?
Yes, ConvertXtoDVD.
But this is not any DVD backuping. Moving you to the conversion forum. -
Like said; convertx2dvd or start reading here: https://www.videohelp.com/guides?searchtext=&tools=&madeby=&formatconversionselect=MKV+...or+List+Guides
/Mats
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
how to join mkv.a and mkv.b files
By sumeshkri in forum EditingReplies: 1Last Post: 5th Apr 2012, 19:56 -
Stripping sections of MKV files to seperate smaller MKV files
By spudz72 in forum EditingReplies: 6Last Post: 29th Jul 2010, 01:53 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 00:45
