Hi,
I'm trying to find the best way to be able to play back 6 discrete channels of surround audio trough my soundcard. I'm thinking of converting the VOB file to an mov with AC3 audio so I can open it in Quicktime. That way I can use the A52 codec for core audio to play back the six channels. Now is my question, the dialnorm imbedded on the DVD, is it stored in the AC3 audio and if yes, with ripping trough FFMPEGX, is going to read the dialnorm and adjust according (+ using compression), or where can you set this?
Robin
Results 1 to 1 of 1
On the fly software AC3 encoding
By djdynamite123 in forum AudioReplies: 12Last Post: 24th Jul 2011, 16:35 -
AC-3 dialnorm freeware
By jdachik in forum AudioReplies: 2Last Post: 3rd Sep 2010, 19:02 -
Arbitrary AC3 Re-Encoding by DVDStyler
By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 6th Sep 2008, 15:57 -
No Audio when encoding with AC3
By Stankia in forum AudioReplies: 2Last Post: 25th Apr 2008, 18:44 -
Adjusting AC-3 "dialnorm" in an existing VOB
By Coises in forum AudioReplies: 13Last Post: 16th Aug 2007, 22:04
