I have a bunch of home made VCD (PAL and NTSC). I have converted some of the VCD to DVD without pain using SVCD2DVD and TDA. Recently I encounter an error msg from TDA while working on some PAL VCD. The error msg was " GOP of the video is too long". Should I choose to proceed then I would end up with a non standard DVD (cannot be played on certain stand alone player).
The only method that I can think of to put those VCD to a standard DVD format is to re-encode in TmpgEnc and select the appropriate GOP length. Is it possible to correct the GOP without encoding?
_jelir_
I've ignored that error many times in the past and the resulting discs have all been fine.
He's a liar and a murderer, and I say that with all due respect.
DVD video has Too Long GOP, What To Do
By Brent212 in forum Authoring (DVD)Replies: 5Last Post: 14th Aug 2013, 09:36 -
incorrect GOP when trying to author DVD with files extracted from VCD
By ibzomie in forum Video ConversionReplies: 2Last Post: 20th Jan 2012, 10:58 -
TDA problem of GOP
By sumeshkri in forum Authoring (DVD)Replies: 2Last Post: 29th Feb 2008, 02:29 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 19:04 -
SCR <> GOP error in Gui for DVD Author
By rain in forum Authoring (DVD)Replies: 6Last Post: 22nd May 2007, 12:51
