Hi, I am getting this message on starting svcd2dvd its version 2.1 on windows xp, I have tried reinstalling but it hasnt worked
an unhandled exception has occured in your application
unspecified error
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error
at QuartzTypeLib.FilgraphManagerClass.RenderFile(Stri ng strFilename)
at x3284ccece41ee22b.x79ed6fa5f8db6479.x535825f93c028 407(String xa39af5a82860a9a3)
at x3284ccece41ee22b.x210ff09a2516b1a7.x92b839eef7ea4 c46(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 2.1.2474.30185
Win32 Version: 2.1.2474.30185
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
DevComponents.DotNetBar
Assembly Version: 5.9.0.0
Win32 Version: 5.9.0.2
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/DevComponents.DotNetBar.DLL
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/AxInterop.CodeLock.DLL
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.QuartzTypeLib.DLL
Interop.DexterLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.DexterLib.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Looks like you don't have the filters required to play a mpeg1 file in windows media player... To confirm can you play the splash.mpg file in the SVCD2DVD folder in WMP?
If you install v2.5 from the registered users area it should solve the problem or you could install something like ffdshow or some other mpeg1/2 dshow filter to resolve the issue.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I have tried 2.5 but when I encode a xvid to dvd I get vertical lines. I reverted back to to 2.1 and encoded the same xvid with no problems
I can play mpeg1 and 2 through media player 11 but not the splash screen I get this error in media player 11 error C00D11B1 -
i have ffdshow on the system and gspot says the codec is there to playback the splash screen, plus media player classic plays the splash screen, so it looks like it may be a fault on media player 11 that is causing the problem
thanks for your help with this this one
unhandled exception - length cannot be less than zero
By warresg in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Jul 2010, 17:49 -
"An unhandled exception occurred in 3rd party module and will be close
By BLSAMPLES in forum ComputerReplies: 4Last Post: 12th Jul 2009, 23:30 -
Unhandled exception error mencoder convert opendivx video - How to solve?
By melaos in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2009, 05:43 -
FAVC 1.06 error - Unhandled exception has occurred in your application
By mcv2008 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jun 2008, 15:15 -
SVCD2DVD error on start up 'Application has generated an exception...'
By Turnstyle in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 16th May 2007, 04:53
