Was just wondering if the order in which you load your filters in virtualdub make a difference on the quality. For example, if I load resize, MSU Denoiser, and than Smart Deinterlace in that order does it make a difference.
Yes
Deinterlace before resizing. Denoiser could matter if you upsize or downsize. If you use the denoiser after downsizing a lot, it would have a lot less pixels to work with so you could go overboard and your picture may not look as good. If you upsize I would use it after resizing. Depending how you order your filters may have an effect on encoding speed also..
I usually use avisynth and its filters though. -
Is there a tutorial on avisynth anywhere?
http://avisynth.org/mediawiki/Main_Page
+reference documentation installed with AviSynth;
AVSP: free script editor with preview/floating prompts/button to call AviSynth docs. -
It depends how much you're downsizing....like for me if I go from dvd resolution of 720x480 and downsize to vcd(352x240) resolution I may just use a denoiser before resizing(but after deinterlacing).Originally Posted by capman21
I am going from 720x480 to 680x480 so I guess it really wont make a difference.
AviSynth and Filter Order
By sambat in forum EditingReplies: 3Last Post: 11th Jan 2012, 10:04 -
Does size really matter?
By ingeborgdot in forum ComputerReplies: 21Last Post: 25th Jun 2011, 10:11 -
So is any DV codec better than MainConcept at decoding? Does it matter?
By Asterra in forum Video ConversionReplies: 11Last Post: 20th May 2011, 22:59 -
best DVD recorder filter & ATI AIW filter
By VCRcomp in forum RestorationReplies: 1Last Post: 27th Jan 2011, 17:27 -
Why does the disc speed matter with the burning?
By coody in forum DVD RippingReplies: 20Last Post: 31st Jan 2008, 18:39
