I've just got a Family Guy DVD and it has no play all feature. Is there any way I can add this to the DVD without having to re-author?
Even if I can make the episodes run one after the other without the play all button would be great.
Thanks in advance
Carl
PgcEdit has a create play all title feature. It works on the titles in a VTS. You'd need to divert a button to the new title.
If the titles are in different VTSs, try re-authoring with DVD Shrink or Recode (no menus) and use PgcEdit's DVD Shrink plugin to make the titles play after each other.
RegardsLes -
You can edit navigation (for making titles play one by one) in DVDRemakePro and use e.g. the button for the first title in top menu or create an invisible auto-activated (after prescribed time) button.
For making titles play consequently you create new empty PGCs in video manager and give them Jump VMG title# pre-commands. To call these PGCs you edit post-commands in PGCs in the titles. Then test and output modified files (mainly ifo's/bup's here) for replacement.
Also suitable for editing navigation in case you'd used one-click join DVDs feature of DVDRemake.
Adding controls to a swf (then adding to website)
By AshleyQuick in forum Newbie / General discussionsReplies: 6Last Post: 14th Oct 2011, 04:02 -
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
Adding watermark to DVD
By carlmart in forum Authoring (DVD)Replies: 8Last Post: 3rd Aug 2010, 13:28 -
Adding Big play button in center of the video
By ras in forum EditingReplies: 5Last Post: 26th May 2009, 21:24 -
Adding Graphics to a DVD
By rlchapin in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 11:41
