Hello, folks
I am pretty new at this and I was wondering which options I should use:
I have two avi files, each of them are about 800 MB’s, and I want to convert them so I can burn them onto a DVD-5 disc. Should I convert them with ‘the FilmMachine’ and let the program itself shrink it so it will fit on a disc, or should I have no decompression and let DVD-rebuilder shrink it after the movie has been converted?
Mark
If it is an AVI file most likely it will be Mpeg4 format, if you expend it to DVD5 Mpeg2 it will be about 4+ Gb. That is one full DVD5. To put two on one disk it will need 50% compression. If that is what you want, FilmMachine is using good encoders so it will be OK to do it with that.
Get GSpot (free) and check your file format in there. -
Always use as few steps as possible.
...and use a more descriptive topic title than "I need a little help" - We all do that.
Source file size is irrelevant when calculating the size of the DVD output. Length is what counts. I'd advise against > 3 hours on a DVD-5 - 2 hours is generally what can be expected with decent quality.
/Mats -
Either way you'll have quality loss...try DVDFlick..see if you like the result, avoid a step....there is also ConvertXtoDVD..
" Who needs Google, my wife knows everything" -
I use the FilmMachine with either CCE or HC, and with one avi file it produce a pretty good image, but I haven’t tried with two avi files, and therefore I ask if the FilmMachine, or any other programs, decompress two files with good quality.Originally Posted by mats.hogberg
Mark -
"good quality" is highly subjective. Apps that use CCE or HCEnc produce about as good output as it's likely to get, without using the encoder yourself, and fine tune its settings (if you have the knowledge) beyond what front ends like The FilmMachine allows.
/Mats
AVS File Steps
By sambat in forum Video ConversionReplies: 23Last Post: 16th May 2011, 13:27 -
First Steps In Premier CS4
By Sundayarak in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2010, 19:09 -
Convert subtitles online in only 3 steps
By countedmond in forum SubtitleReplies: 0Last Post: 28th Oct 2008, 12:27 -
Steps to ensure best video shoot
By bowmah in forum Newbie / General discussionsReplies: 4Last Post: 26th Sep 2008, 22:17 -
Steps for remuxing WAV into DV-AVI?
By sd_smoker in forum Newbie / General discussionsReplies: 3Last Post: 27th Jun 2008, 12:20
