Hi everyone!
I am at MY WITS END with this problem.I am trying to convert a couple of AVI files using either Nerovision express or VSO DIvX To DVD.
I have converted many AVI's before using these but for some reason, everytime I try and open up the AVI file in either of these programs (and a few others I have tried as well) it just shuts down the program.
Can anyone tell me what is going on? As I say, i've used these programs before to convert to VOB and IFO etc, but with the two AVI's in particular, it just shuts down as soon as I open the files in the program!
Any help would be appreciated sooooo much!
Thanks everyone!
Justin
	Drop the avi into gspot and tell us the exact details of the AVI (framerate, framesize, codec, audio format etc.) .. could be almost anything causing the problem. You are in breach of the forum rules and are being banned. Do not post false information.
 /Moderator John Q. Publik
	To take a wild guess, based on assumption and very little information, I would say you have corrupt codecs. Installed any codec packs ? Can you play the files back in WMP ?
 Follow Mr Troll's advice and g-spot the file, then try actually playing it back.
 You might also try loading it virtualdub or avi demux, seeing if you get any errors, and doing a direct stream copy of the file.Read my blog here.
	Not really. That a video file is OK for playback, doesn't imply that it's also good as source material for further conversions. Players are made to be error tolerant. Encoders need each and every frame to be in good shape.Originally Posted by xxjustinukxx
 /Mats
	Hi again!
 ok, I tried opening the files in gspot and the program just crashed, shut down, just like the others! Also, i opened the files in virtualdub and it crashed with the error message..
 "An integer division by zero occurred in module 'xvid'."
 please help!
	Hi I had exactly the same problem after installing the nero 7 trial on my laptop try using Windows XP AVI Fix from here.
 http://www.tnk-bootblock.co.uk/software/index.php?type=unsupported&id=B2B5C56B
  Handbrake like software for .avi files?By prohank in forum Video ConversionReplies: 4Last Post: 6th Apr 2011, 12:16
  AVS Media "demo" file-conv S/W inserts voice into cvtd music filesBy charlessmall18 in forum AudioReplies: 0Last Post: 2nd May 2010, 17:17
  How to burn avi files using nero 8?By funkymonk in forum Newbie / General discussionsReplies: 2Last Post: 22nd Sep 2008, 02:23
  How to burn avi files to neroBy crocker5731 in forum Authoring (DVD)Replies: 2Last Post: 27th Sep 2007, 21:13
  How do I merge 2 .avi files? (using which software)By Hank Kinsley in forum Newbie / General discussionsReplies: 3Last Post: 9th Jul 2007, 00:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
