    Apr 2005
    California
    Hi.
    I d/l the latest trial of Nero to use with DVD Shrink. I used DVD Shrink to load VANILLA SKY to my HD. As it turns out, VANILLA SKY is a bit too large to fit onto a blank DVD-R. I did some research on this, and others have confirmed this. Anyway, it looks like DVD Shrink divided the movie into 4 parts: VTS_02_01.VOB and so on. I went to Nero to create a DVD using each part as a title -- no menus or bonus stuff -- just the movie. The result was that it wouldn't burn.
    Any ideas on what I did incorrectly?
    I saw a guide from a member here for TMPGEnc to re-encode, but I honestly couldn't get through the initial step that he has screen shots of, so I tried this other "lamer" way.
    Thanks for your positive feedback.
    M_B_D
    Apr 2004
    Miskatonic U
    DVD Shrink will reduce the movie to fit a single layer disk. If you use re-author mode you can drag just the main title across from the right to the left pane. Press backup, and select whether or not you want Nero to burn.
    Read my blog here.
    Apr 2005
    California
    Thank you so much. It worked just fine
    M_B_D
