Hi guys
I'm new to all this so be gentle please!
I've recently got a new TV witch can display 1080i and an Xbox 360 hooked up to it. When I've been downloading stuff I've generally been getting avis and the such and using Transcoder360 to play them, but I want a bit more quality now. A couple of the files I've downloaded are iso files, from which I gather is a container rather than an actual video file type.
What I would like to do is get the films of these isos, in the best possible quality to enjoy on my shiny new TV! And while I'm here, I have a random mkv file. I tried to follow a guide on here but got a bit lost. Any tips for these too?
Thanks in advance
Matt
If you want best quality get a HTPC!
or just download high resolutoin wmv/vc1 videos for you xbox 360. Converting will always decrease the video a bit.
You must extract the content from the iso files to be able to convert. Use for example isobuster, daemon tools, etc. Then convert with tools like Videora Xbox360 Converter, AutoMKV using high bitrate and you wont lose that much quality.
Have you also tried tversity to stream to your xbox? Maybe better quality than transcode360. -
Thanks for getting back to me so quick.Originally Posted by Baldrick
I've got TVersity as well. For whatever reason, both Transcode360 and TVersity occaisonlly don't want to work with a particular file, I generally find the other one will.
Right, I've got the gist of what you mean, so I've opened my image in Isobuster, and clicked on where it says ISO in a little red box. Now, do I extract both VIDEO_TS and AUDIO_TS?
EDIT : got past this bit now! -
Aha! Now the question is when I've extracted the Video foler, it's obviously all come as seperate VOB files. If I put these through Videora, will it join them as one in one wonderful unison?
It doesn't actually "join" the vob files...it extracts the video/audio into a single file.
Google is your Friend
Converting videos for playback directly on Xbox 360...
By kevinmd88 in forum Video ConversionReplies: 3Last Post: 17th Aug 2011, 23:09 -
Converting VOBs to Play on my Xbox 360
By Wumpscut in forum Media Center PC / MediaCentersReplies: 9Last Post: 26th Apr 2011, 20:37 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Converting DV-AVI and AVCHD for XBox 360
By eyeSpy in forum Newbie / General discussionsReplies: 1Last Post: 8th Apr 2009, 03:28 -
Need felp converting MKV file so it plays on Xbox 360
By wwervd316 in forum Newbie / General discussionsReplies: 6Last Post: 7th Mar 2008, 22:29
