i tried to encode a dvd2avi project with tmgg (using latest version 12h). I used 3 different films so i think there is no problem with the dvd2avi project. but tmpg stops encoding after 2 or 3 hours and my pc is down. there is no error message and i disabled the screensaver and powermanagement.
i tried to encode several films for 3 times but it always stops.
Heeeeeeeeeeeeeelp!
I´m using win98se on a 950athlon with 256mb ram so there are no speed problems i think, before i used win se and it fits.
I'm having the same problem. I have been encoding for a few weeks just fine. Now out of no where it locks up after awhile never in the same place. My power settings are all off. I have tried a few more things and will reply if it works. It sure is a long process to see if it works !!!!
Check your CPU temperature. That was the problem on my computer. The heat sink and fan were not doing a good enough job keeping the CPU temperature down.
---JDP
Megui encoding stops
By sanosuke in forum Video ConversionReplies: 1Last Post: 20th Dec 2012, 21:36 -
BD Rebuilder stops encoding
By pepegot1 in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Jun 2011, 10:01 -
AVStoDVD stops working after encoding video
By tperkins13 in forum Authoring (DVD)Replies: 1Last Post: 19th Apr 2011, 07:10 -
AlltoAvi Stops Encoding Prematurely
By Startropic1 in forum Video ConversionReplies: 3Last Post: 6th Jun 2009, 19:49 -
DVD authoring and encoding on TMPG and Ulead
By bellyting in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2007, 16:53
