Hi,
Kindly advice me about converting a dvd into a vcd file.Subsequently i would like to join the resulting mpeg1 file with another file for a final vcd.
Thanks in advance.
you can rip the dvd to your hard drive, then use vob2mpeg to convert to mpeg-2, then you would have to re-encode down to mpeg-1. Out of curiosity, why are you trying to do this?
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
DVDx will go direct from a DVD to VCD as will Easy VCD
Not sure how either work with modern protection systems on DVDs
If you Rip to your Hard Drive and use VOB2MPEG then Womble do a couple of
programs that will allow you to join files together and save the result as a VCD
compliant MPEG1 stream, although I am sure there are many other
editors that will do this as well.
Not sure what you are hoping to achieve tho' since the drop in quality compared
to DVD quality MPEG2 is considerable
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 16th Jun 2010, 23:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 10:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
