I convert a lot of movies to vcd and burn them as data on a dvd disc, and my dvd player plays them this way. I do this because this allows me to get two movies on one dvd. Problem is my dvd player control doesnt work most of the time now. So do you know of any dvd player that will play them as data? The dvd player I have now is XWAVE, and I cannot find a single univeral remote that will operate it.
If you look to the left in 'DVD Players' and select 'MPEG1/2 ISO' for a search, that should tell you which ones will play a MPEG data file:
What is MPEG1/2 ISO in the DVD Players list?
MPEG1/2 ISO is if your standalone DVD Player supports MPEG1(VCD), MPEG2(SVCD,DVD) or/and VOB(DVD) files with no authoring, like you are able to select any MPG/MPEG/MPV/VOB files from the CD/DVD using a file browser and play them
Software and data files vs. playing movies - special dvd player?
By Haopengyou in forum Media Center PC / MediaCentersReplies: 3Last Post: 18th Mar 2012, 06:55 -
Playing Multiple DVD Players on a PC?
By Tchail in forum Software PlayingReplies: 9Last Post: 28th Dec 2011, 13:59 -
Playing AVI Movies as data files with menus
By shans in forum Authoring (DVD)Replies: 25Last Post: 10th Mar 2011, 09:43 -
Proshow DVDs not playing back on Blue Ray Players
By papadish in forum Newbie / General discussionsReplies: 0Last Post: 9th Oct 2009, 10:33 -
Trouble Playing a DVD in software players
By AfroPuff in forum Software PlayingReplies: 5Last Post: 26th Oct 2008, 19:00
