Hi All,
I have the Matrix Widescreen format and I am trying to convert it to full screen so the entire iPod video screen is filled with the movie. I've tried CloneDVDMobile,Cucusoft,Xilisoft,Super Converter, and all the iPOD-encoded movies have the black bars at the top and bottom. Yes, I turned off Widescreen in iPOD video settings.
I've tweaked the settings for the applications that I've used to encode as 4:3 (Xilisoft), Letterbox zoom (CloneDVD), etc. and none of them seem to work!!
I didn't have any trouble with LOTR Fullscreen (obviously..)
Thanks for any tips!!
P.S.: Right now, at home, I'm encoding the movie using Nero Recode that has iPOD support. When I get home from work, I'll check it out and see if the bars are gone.
Your original video may actually be full screen, boxed off to 16:9 size. When you play the video in quicktime, does it show as 4:3 with black bars, or as 16:9 with no bars? Make sure the copy of the movie you own says "anamorphic" widescreen on the back.
Hi,
I am not work - I will check in a couple of hours (I'm at work now). I believe the video is 16:9 with bars on teh top and side (this is how Power DVD played the movie). I remember the word "WIDESCREEN" on the front cover. However, I'll double check to see if it says "anarmorphic" on the back
Thanks!
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 08:24 -
Widescreen shows up on the PC but as fullscreen on the TV?
By Moontrash in forum Authoring (DVD)Replies: 8Last Post: 17th May 2010, 17:26 -
Fullscreen vs. Widescreen: why still airing new content in fullscreen ?
By vhelp in forum DVB / IPTVReplies: 56Last Post: 2nd Oct 2009, 14:54 -
How to convert fullscreen to widescreen and vice versa?
By coxanhvn in forum Newbie / General discussionsReplies: 7Last Post: 16th Jul 2009, 23:01 -
Widescreen To Fullscreen
By OG24 in forum Newbie / General discussionsReplies: 10Last Post: 11th Aug 2007, 15:51
