    Jun 2007
    hey all
    im a newbie to burning DVD's.
    Basicly my problem is that when i playback my DVD's i create on the DVD player it jitters all the way threw.Works on my built in DVD player on my TV
    but down stairs DVD player Jitters ALot so i cant watch them.
    Heres How im burning my DVD's
    i download the .avi movie. i use WinAVI video converter. add my file choose destination and convert. when its done i have DVD_01 with subfolders Audio_ts and Video_TS
    then on WinAVI i click burn to cd. i add the files burn at 16x or sumtimes 8x and iclick burn. i play back and it jitters alot.
    DVD's i use are emotion DVD-R/ 1x-8x / 4.7GB and maxell DVD+R 1-16x speed
    both sets of DVd's burned at my method play jittery on other players other then my bush TV/dvd combo
    can anyone help me out on how to make them play on other players
    thanx hope i posted in right area with enough info
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Hi! Welcome to VideoHelp!
    1) WinDVD is crap. If your limit is oneclickwonder applications, try Convertx2dvd. If you like to learn the trade, take a look undser CONVERT left, for guides on almost anything to DVD.
    2) Try a different (better?) kind of media. Different players like different media. Take a look at www.nomorecoasters.com for a rundown of what's good and not.
    /Mats
    Jun 2007
    /Mats
    hi thanx for your reply i will try the Convertx2dvd program, do you think i shud burn at slowest speed? would this help
    Oct 2006
    Canada
    If you check few posts on this web sit, you will realize that DVD media is an important part of successful burn.
    Check this out
    http://www.digitalfaq.com/media/
    http://www.cdr-zone.com/reviews/dvd_media_reviews/
    https://www.videohelp.com/dvdmedia
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Generally, good media should work fine even if burned @ max speed. I however tend to never burn faster than 1/2 max speed. There's no hurry...
    /Mats
    Jun 2007
    /Mats
    i read up on maxell and there ment to be gud. but they do jitter on 2players ive tested on :S
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I'm not saying that you definately are looking at a media problem, but unfortunately, different players, like I said, like different media, not always the generally "best" media.
    So - Try something besides WinAVI - a safe source of all kinds of problems.
    If that doesn't help - try some other media.
    /Mats
    Nov 2003
    Everywhere I want to be
    Another "long shot" item to check...
    What's the bit-rate of your final DVD? I had that happen recently when a disc would play fine on my machine but jitter like mad on a friend's. I had accidentally set it WAY too high. Once I dropped it the disc worked on both machines.
