    Jun 2007
    I was wondering, if there is somebody out there that can help me with my problem.
    What I would like to do is edit a mpeg file, what i want to edit is the the screen, i want to freehand crop the screen to what ever shape or size i prefer.
    What i am currently doing is making a motion menu for superman, and what i would like to do is change the screen size to the same as superman logo, (S in a Shield)
    Is it possible.
    Please help and advise to send me in the right direction.
    Thank You.
    Dal.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    photoshop or you will have to use a mask as in sony vegas -- but mpeg is not your best source material for this
    Jun 2007
    any information on how to this, how to mask and use photoshop or vegas, please.
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    do a search for Bezier curves using vegas , or tutorials on photoshop
    both of these are for the non novice user
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    @dbanga: If you, like the rules suggest, try using a more descriptive topic title than "Advise Required", maybe more will come here with suggestions...
    /Mats
    Nov 2003
    Everywhere I want to be
    You didn't mention what software you were using so...
    There is a tutorial on how to do something like this with EditStudio you can see by clicking here.
    The tutorial shows how to make a mask to make titles fade at the top and don't show on the bottom of the screen. But if you used a video file, you would get the same "in a shape" effect.
    There is no restriction on the shape of your matte; wherever you have white you will see your video, wherever you have black you won't see it, wherever you have grey you will see a faded version that depends on how dark the grey is.
    Adobe Premiere tutorials, for this concept, are at www.wrigleyvideo.com in the guides. It's not going to say "make a cut-out for a menu", but this concept is covered in another guide. Look for it.
